350+bhp and no lag?!
Old Dec 13, 2005 | 12:17 AM
SteveH's Avatar
SteveH
Default 350+bhp and no lag?!
Thinkin of buildin a new cossie in the new year, and want to try a slightly different spec this time.
The last cossie had the usual stg3 bits: T34, 500 cooler, greens, cams, LOW COMP (7.5:1) etc. but this time i want as little lag as possible.
SO, i'm thinking of something along these lines: 200 block, balanced crank & rods, ported & polished head. roller bearing turbo (GT30?) with ext wastegate. The comp ratio is where i'm thinking of making the big difference, as i was contemplating raising it to 8.5 or maybe even as high as 9:1. I'm not sure on injectors or map yet, advice appreciated.
As i'm only aiming for 350bhp (but with massive torque this time) will this comp ratio be ok?
Please discuss: any help is brill, ta!
Old Dec 13, 2005 | 10:30 PM
twitchyrear's Avatar
twitchyrear
post this up in general discussion room and youll get answers matey
Old Dec 14, 2005 | 09:12 AM
SapphyMike's Avatar
SapphyMike
dont bother with a GT30 and external wastegate - it will be complete overkill for that engine..
You're basically after a rally type engine (low power, lots of torque).
Old Dec 14, 2005 | 03:04 PM
Azrael's Avatar
Azrael
Originally Posted by SapphyMike
dont bother with a GT30 and external wastegate - it will be complete overkill for that engine...
What about GT-28RS in Ford fittment?
Old Dec 14, 2005 | 06:03 PM
markk's Avatar
markk
comp ratio will be fine at 9.0:1, turbo is a bit overkill tho as said
Bailes1992
Sep 3, 2015 02:17 PM
Bailes1992
Aug 16, 2015 07:14 PM
escort-cossie-owner
Jan 5, 2005 08:51 PM
cozzie4d
Oct 7, 2004 12:56 PM
Mr C
Jul 28, 2004 05:58 PM
