T28 BOOST PROBLEM
Old Nov 29, 2003 | 06:01 PM
chRiS & dawn's Avatar
chRiS & dawn
Default T28 BOOST PROBLEM
My cossie is running hardly any boost at all.
On standard boost gauge can only get it to just past large segment (not sure what boost that is) and car just feels dead at that point.
I have tried a different actuator which i believed to be standard and boost was less. The one on the car felt stronger which i have now put back on.
I have tried running with pipe from actuator disconnected (briefly) to see if elekron valve was problem and boost was marginally better but still not good.
I have since fitted a GGR chip and car feels a bit better at low revs but still same max boost level.
Any ideas what else it might?
I,m thinking turbo not holding boost but its doesn't smoke use any oil at all. Theres some side to side play on shaft but no in/out movement.
Thanx in advance
Old Nov 29, 2003 | 06:35 PM
Guinnless's Avatar
Guinnless
The turbo may be generating boost but being leaked off somewhere. Check for split hoses.
Old Nov 29, 2003 | 06:45 PM
Toe Knee's Avatar
Toe Knee
AS said check hoses, u got a dumpvalve btw?! cos theses are know to leak boost alot.
Old Nov 29, 2003 | 11:03 PM
Stu @ M Developments's Avatar
PassionFords Creator
As suggested, it will be the dump valve in 90% of cases.
Old Nov 30, 2003 | 04:52 AM
XR4Timan's Avatar
XR4Timan
These damn DIAPHRAM dump valves are kak but they sound nice - get it repaired, replaced, blocked or best still, get a piston type!
Old Nov 30, 2003 | 10:15 AM
Have you adjusted the actuator to let the car boost more? When my car was chipped i had to remove the amal valve and set the actuator.
Old Nov 30, 2003 | 02:32 PM
chRiS & dawn
Do u mean standard dump valve causes this problem if faulty or just aftermarket ones if fitted?
Old Nov 30, 2003 | 02:44 PM
Both... but the standard one failing is more common TBH.
Old Nov 30, 2003 | 06:18 PM
chRiS & dawn
Cheers Stu
How can i check standard if dump valve is failing?
Thanx Chris
Old Nov 30, 2003 | 08:33 PM
Easy..
Put a pipe onto it, and suck.
If you can suck air through it, its knackered
JK12
33
Apr 26, 2021 12:09 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
