Boost for stage 1
Old Nov 27, 2003 | 02:33 PM
Default Boost for stage 1
I have a 2wd saphh with a 4x4 engine with a stage 1 chip.
Fuel pressure is on 3.5 bar.
What's the max. boost pressure, continue and peak: example 1 bar peak and continue 0.8
Greetz
Old Nov 27, 2003 | 02:46 PM
Guinnless's Avatar
Guinnless
Depends on whose chip, mate. Ask them.
Old Nov 27, 2003 | 03:32 PM
I don't know where the chip is from, but wich boost is safe to drive without damage anything like the headgasket or something.
Greetzz
Old Nov 27, 2003 | 07:39 PM
steveRS's Avatar
steveRS
hold 1 bar or 15 psi m8
Old Nov 28, 2003 | 01:47 PM
Switch's Avatar
Switch
dunno what chip mine has but peaks at 17-18psi and holds 15psi
Old Nov 29, 2003 | 02:06 PM
Stu @ M Developments's Avatar
PassionFords Creator
It 100% depends on the chips mapped injector duration so this question has no answer im afraid.
Old Nov 30, 2003 | 04:47 AM
XR4Timan's Avatar
XR4Timan
It's safe to say that all Stage 1 chips run good till 14.3 lbs of boost - some require green injectors so i'm told!
Old Nov 30, 2003 | 11:35 AM
Its never "Safe" to assume anything im afraid..
Say that chip was for a 7.2:1 lump.. she would have circa 30degrees advance at peak torque with a bar of boost....
POP!!
Test... dont guess.
I also had a car in once, bought a second hand chip of a mate, hit the motorway at 16psi and didnt make the next slip road before he melted THREE pistons...
Brought the car to me for investigation, chip was indeed fine.. very odd
Took the head off and it became immediately apparant why it melted...
The head had 26mm ports!!
Old Nov 30, 2003 | 03:35 PM
XR4Timan's Avatar
XR4Timan
Well Stu, when I buy a Stg 1 chip from PJ Moto, Amber, GGR, etc it's safe to say it'll be safe to 14.3 lbs of boost.
An unknown chip you inherit classed as a stage 1 is like a box of chocolates - u never know what ur gonna get. It may NOT even be a Stage 1 at all. You're right -in the end, it's buyer beware.
Old Dec 1, 2003 | 07:26 PM
TIFF's Avatar
TIFF
Chasing Radders
My stage 1 spikes 26 psi and holds 22psi
But like Stu said,100% depends on the map
Old Dec 1, 2003 | 07:29 PM
XR4Timan,
Read my post above you........
Old Dec 1, 2003 | 10:05 PM
XR4Timan's Avatar
XR4Timan
Ninny?? or Twat??
Old Dec 2, 2003 | 08:38 AM
Old Dec 2, 2003 | 09:41 AM
Guinnless's Avatar
Guinnless
Originally Posted by XR4Timan
Ninny?? or Twat??
Que??
Old Dec 2, 2003 | 03:47 PM
XR4Timan's Avatar
XR4Timan
Ninny or twat? What comes after "you....."
Get it? Trying to make fun of myself as usual
Old Dec 3, 2003 | 06:32 AM
I get it now......
Old Dec 3, 2003 | 04:11 PM
Smit's Avatar
Smit
The 60ft Launch King
derrrrrrr
and 26mm ports? can some1 explain to a thick user in english
Old Dec 3, 2003 | 08:23 PM
Guinnless's Avatar
Guinnless
Originally Posted by Smit
derrrrrrr
Big ports. The head flowed more than the chip was mapped for. Lots of air but not enough fuel...det...det...det
Old Dec 3, 2003 | 08:28 PM
Smit,
derrrrrrr
Double derrrrrr......
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
Russ Payne
Sep 25, 2015 08:29 PM
