smokey fiesta. help!!
Old Nov 20, 2005 | 06:09 PM
grease monkey's Avatar
grease monkey
Default smokey fiesta. help!!
hey people i have a fiesta turbo and it is very very smokey when warming up but doesnt smoke when it is warm.
first though it was the valve stem seals and as im a trained ford mechanic i replaced them as well some of the valve guide. but to my digust that didnt solve the problem .
so i started goin down the engine road done all sorts of tests and then a friend convinced me to rebuild the engine which i did myself i relaced rings bearings i even bought a new cam kit which left a healthy hole in my pocket (it was worth it though) rebuild the head from scratch re seated all the valves and put the engine back together perfect.
this also didnt get rid of the smoke but the car goes really well the engine is sweet . so it has to be the turbo right . well im just after rebuilding that got it professionally balanced new seals the lot but now the smoke is now worse . it will only smokes on warm up and it will only happen when its at idle when its on boost its fine and it drives great and no smoke
as far as i know this should not happen. has anyone ever come across anything like this. im going mad i just feel like gettin rid the car or putting a match to it
any help would be greatly appreciated
Old Nov 20, 2005 | 07:32 PM
Alvyn's Avatar
Alvyn
check the turbo oil return pipe the oil to the block one it's clogged up over the years and so the oil from cold/warm CANT return quick enough so stays in the turbo that bit longer thus causing the burning of oil IMO!
Old Nov 20, 2005 | 07:53 PM
stusfesta's Avatar
stusfesta
i had this problem, bought a new turbo but still did it. Got a big oil return pipe fitted and sorted it.
Old Nov 20, 2005 | 07:56 PM
boost mad's Avatar
boost mad
what colour is the smoke
Old Nov 20, 2005 | 08:22 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
yip breathers or oil return m8
Old Nov 20, 2005 | 08:51 PM
Alvyn's Avatar
Alvyn
take it to be blue
Old Nov 20, 2005 | 08:59 PM
grease monkey
im pretty sure i checked that pipe i think i even took it off and had a look at it it was ok and i checked it in the block seemed ok but maybe its kinked i must look again thanks mate. i did clean out the breather sytem aswell thats fine.
thanks alot for the quick replys and suggestions . im absolutely head wrecked ill tell how i get on wish me luck
Old Nov 20, 2005 | 09:06 PM
grease monkey
yeah its a thick whitey blue .
i started it tonight and it covered my whole road im surprised the fire brigade wasnt called
Old Nov 20, 2005 | 11:54 PM
SafeChav's Avatar
SafeChav
hmmmm im having a similar problem with my cabriolet
endless list of problems, but after being off road ALL SUMMER i started it up all excited tons of blue smoke, had a bit of a head scratching session, found a valve guide pushed in, cant see how it happened or why it didnt smoke before but ANYWAY got a new valve guide fitted, £80 later and head re-fitted, it starts and smokes for about 30 seconds then is fine
the engine was rebuilt 3.5k ago??????????
Old Nov 21, 2005 | 08:16 AM
Alvyn's Avatar
Alvyn
[quote="grease monkey"]im pretty sure i checked that pipe i think i even took it off and had a look at it it was ok and i checked it in the block seemed ok but maybe its kinked i must look again thanks mate. i did clean out the breather sytem aswell thats fine.
I've had them pipes look mint on the outside but under the braided part the pipe inside MUST be fucked cause what you describe is a VERY common fault some people end up running a t3 turbo or selling the whole car cause they CANT suss it out
you may have to get a pipe made thou as their NLA from frauds
Old Nov 21, 2005 | 05:53 PM
stusfesta's Avatar
stusfesta
It is a fault with the frst mate, something about the angle of it. mine used to fill my whole road up for 5mins. it really is worth having it done you will be surprised, it solved it for me
Old Nov 21, 2005 | 06:53 PM
barry0777's Avatar
barry0777
hi had the same on my rst escort been told buy ford that the car iv got is or has got as history or blowing the turbo seals and it has endls turbo truble iv later found that the oil pump was over pressuring cousing to much oil at once so changed the pump and all is fine but im gona take it out for a proper test just to see how it has workes or not ??????
Old Nov 24, 2005 | 05:15 PM
grease monkey
well i got a new pipe in from ford cost 40 euro should of been more but luckily i get staff discount goin to replace it soon hopefully.
if that doesnt work i have a t3 turbo and escort engine in a project mk2 fiesta i will just put that turbo on but i dont really want to it all seems a bit messy. i have an oil pressure gauge on the engine and the pressure does seem within spec .
i did have 2 valve guides replaced before cause they did slip further into the head so thats all covered.
as far as i can see it has to be this poxy pipe
right im goin out to brave the elements
Old Nov 24, 2005 | 06:53 PM
Alvyn's Avatar
Alvyn
right im goin out to brave the elements [/quote]
let us know how u get on!
ps remember the smoke WILL be there for a while after
Old Nov 24, 2005 | 07:13 PM
stusfesta's Avatar
stusfesta
get a big oil return conversion, it will solve it trust me cos sounds like the oil is building up in the turbo from where it cant get through quick enough. look in your intercooler and the pipes that go to the intercooler bet they are covered in oil inside
Old Nov 24, 2005 | 07:17 PM
SafeChav's Avatar
SafeChav
is this common to Escorts aswell?
Old Nov 24, 2005 | 07:25 PM
stusfesta's Avatar
stusfesta
i dont think so
Old Nov 24, 2005 | 07:30 PM
SafeChav's Avatar
SafeChav
oh
just getting a few seconds of smoke from mine on startup.
Its done 3.5k on a rebuild, head has just been re-fitted as i had to change a valve guide, so therefore its got brand new stem seals. I re-built the turbo myself while the head was off, with a minor service kit which had all new bearings, thrsut bearings and oil seals.
I also replaced the oil return hose as the old one was split, but i used to a samco 90 degree elbow, was a nightmare to fit looking at it now, a 45degree would of done it better. Could possibly be getting a build up in the pipe??
Is oil in the boost pipes a reult of oil pressure building up in the turbo?
Old Nov 24, 2005 | 07:34 PM
stusfesta's Avatar
stusfesta
if you have oil in the boost pipes then either turbo seals are gone or the oil just cant get out of the turbo as quick as it gets in so you get a build up. sure it aint condensation for few seconds?
Old Nov 24, 2005 | 07:39 PM
SafeChav's Avatar
SafeChav
no i know exactly what you are saying though, i start it, after about 2 seconds the blue smoke comes out, for about 10 seconds which by then steam has also started coming out, but u can tell the difference in the colour.
Well to be honest the car never ever smoked before, but the turbo was second hand, and i had the head off so i thought i may aswell re-build it as chances were it would of gone soon.
All it does literally is this tiny smoke when it starts and no other time.
The only other thing is ive changed oil since putting the head back on.
Before it had comma 5w40 for the initial 3.5k, i thought it deserved a change, and now im using Mobil 1 10w40 as my mate works for Renault and gets it me free (cheers dan), thats the only other thing that comes to mind is perhaps its the different although i cant see that would make a difference. Although slightly thicker..?
Old Nov 24, 2005 | 07:50 PM
stusfesta's Avatar
stusfesta
hmm not sure if that would effect it. take one of ya pipes off and see if there is any oil about or any oil in the intercooler. just keep an eye on it and see if it gets any worse
Old Nov 24, 2005 | 07:56 PM
stusfesta's Avatar
stusfesta
this is what my pipes looked like before i had oil return pipe conversion:
and finally..........................RIP
Old Nov 26, 2005 | 09:45 AM
grease monkey
i just put a new pipe on last nite it was a bastard to fit it sits at a bit of an akward angle .
anyway i cut the old one open and sure enough it was kinda crushed hooray for hollywood put the new one on as i said it was tight . i think it mite be a bit better but still a bit smokey have to run it a bit more . atleast if it doesnt fixed the problem it mite help.
where can you get an upgraded oil pipe ?
grease monkey
o yeah that is what my turbo looks like alright bits of oil here and there
Old Nov 27, 2005 | 09:00 PM
Alvyn's Avatar
Alvyn
where can you get an upgraded oil pipe ?[/quote]
had one made by a company over here called Pirtex
Old Nov 28, 2005 | 03:18 PM
SafeChav's Avatar
SafeChav
[quote="stusfesta"]hmm not sure if that would effect it. take one of ya pipes off and see if there is any oil about or any oil in the intercooler. just keep an eye on it and see if it gets any worse
well there was a tiny amount of oil in the pipes before, no puddles or anything like that.
I have literally only done a few miles in the car since re-fitting the turbo, no serious driving as yet? That new pipe doesnt fit fantastically on the oil return though, so the oil might be building up when i first start it? I'll have to do some experimenting.
VERY NICE CAR BY THE WAY
Why the R.I.P ???? has it died a death?
Old Nov 28, 2005 | 04:50 PM
grease monkey
my car doesnt seem to be clearing up i think im goin to have to make a pipe or somethin and if that fails its the t3 route then
TPM961
Jan 15, 2018 10:50 AM
sridgett
Oct 1, 2015 07:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
Andypandy260
Sep 23, 2015 10:28 PM
Adam-M
22
Aug 10, 2015 10:46 AM
