FRST SICK AGAIN!!!! Anybody help?
Old Nov 15, 2005 | 09:37 AM
fiestar5t's Avatar
fiestar5t
Default FRST SICK AGAIN!!!! Anybody help?
can anybody help again!!! i brought a fiesta rst a few weeks back and it was running great untill it wouldnt start the other day so i called out the aa and it turned out to be an alternator!! they came out fitted one and it was working ok for a few days then it wouldnt start again i cleaned up the connectors from the starter motor and hey it worked for a day!!!!! then wouldnt start, my mate has looked at the alternator and he thinks the aa have put the wrong one on (55amp for a 1.3) when it should have a (75amp for a 1.6) the car it just not holding charge!! would this be the reason for car not starting as its not holding charge,??its doing my headin as im now driving around in a 1.4 saxo furio!!!!!! !! i want my car back!!!!! any suggestion again would be appreciated!! cheers
Old Nov 15, 2005 | 10:14 AM
jonnyturbo's Avatar
jonnyturbo
i know this might sound silly, but this has happened to me before, get a new battery. as winter kicks in it just kicks hell out of a battery on its last legs. whenever i get a new car i change battery before winter kicks in.
i would also look into the alternator but definately try the battery first,
Old Nov 15, 2005 | 10:24 AM
fiestar5t's Avatar
fiestar5t
when the aa came out they said the battery was fine but i did have it on charge the night b4 so i might not have shown up on there tests!! cheers mate ill give it a try
Old Nov 15, 2005 | 12:10 PM
jonnyturbo's Avatar
jonnyturbo
il even bet u a pint if you change the battery it will be sorted. this has happened to me so many times before
Old Nov 15, 2005 | 01:41 PM
antony215's Avatar
antony215
Escort Rs Turbo
Get a new battery mate sound's like the battery ain't holding a charge
if it still duz it after you've put a new battery on then something is draining the battery make sure nothing is left on like the light in the boot or an amp (if you have one)
Old Nov 15, 2005 | 07:38 PM
fiestar5t's Avatar
fiestar5t
Default BEER IT IS THEN!!!!
Ok mate your on ill get one in the next few days and let you know wot the out come is!!!!
Old Nov 15, 2005 | 08:15 PM
jonnyturbo's Avatar
jonnyturbo
where you from? you want my adress so u can post it to me
Old Nov 19, 2005 | 10:11 AM
cos jon's Avatar
cos jon
When i had my fiesta turbo i had 5 alternators, and two batteries !!!! in the space of Three years !!
Old Nov 19, 2005 | 10:19 PM
AKRS1's Avatar
AKRS1
Sounds like battery not holding charge could be a fooked up battery need to get it tested with the car ignition off or you could have something thats draining it. I had this problem once turned out my boot lock was jammed which was keeping the boot light on inside in turn draining the battery.
Old Nov 21, 2005 | 02:28 PM
fiestar5t's Avatar
fiestar5t
Superb thanx for that i will check that when i get home bin away so aint had time to check it out yet
Billy_RS
16
Oct 11, 2025 09:41 PM
gambo08
Fiesta RS1800/RS Turbo
Sep 16, 2015 08:10 PM
bigryrs
Sep 5, 2015 02:57 PM
rsturbo27
Sep 1, 2015 09:54 PM
bigryrs
Aug 28, 2015 05:32 PM
