ecu change from l6 to l8
Old 17-10-2005, 12:22 PM
JjCoDeX75
JjCoDeX75's Avatar
Default ecu change from l6 to l8
Hi all
This is really a follow on from my previous question (re smoking cossie).
How much better is the l8 4x4 ecu over the l6 ecu? Is it worth the change, or is it better to just dump it and go for a complete aftermarket?
Your thoughts please!
JJ
Old 17-10-2005, 12:25 PM
Dave Henshall
Dave Henshall's Avatar
i dont think you would be able to notice the difference between a correctly mapped L6 and L8, the only advantage of the l8 (IIRC) is that is has more memory and therefore can have more load points than the l6....
Old 17-10-2005, 12:40 PM
DazC
DazC's Avatar
As Dave said, L8 has twice the memory capacity of L6. The L8 can also do closed loop fueling which is the only mod on a Cossie which will actually save you money instead of costing! L8 has facility to part control the air con (on the late Sapphire).
Old 17-10-2005, 08:21 PM
JjCoDeX75
JjCoDeX75's Avatar
Cool.
I was thinking of changing for an aftermarket jobbie anyway - thanks for the info
JJ
Old 17-10-2005, 10:24 PM
boost mad
boost mad's Avatar
is it a striaght wap tho?
wud i have to get a different chip to match spec, even i the car was stanard ( as exapmle ), i mean wud a l8 run a standard early cossie ( l6 ) ok, or would all the fueling etc be out
Old 18-10-2005, 08:34 PM
CosRush
CosRush's Avatar
Dont forget too, there are 2 L8's, the Red and the Green label.......
red is the Non Cat version whilst green is the Cat version.
Old 18-10-2005, 08:40 PM
Dave Henshall
or more correctly, without lambda control and with
Old 19-10-2005, 06:11 AM
CosRush
CosRush's Avatar
er no.....
Ford Sierra/Sapphire Cosworth 4x4 non-Cat
Sierra/Sapphire Cosworth 4x4 Cat........
As per Weber-Marelli MPi Technical.........
and......
"Can be recognised by not having mounting flanges and a green or red label with WD48.08.
The one with the green label and second code IAW048/01 is for the catalytic convertor (US83) model.
The one with the red label and second code IAW048/02 is for the non catalytic convertor (15/04) model."
Old 19-10-2005, 09:58 AM
sevans
sevans's Avatar
You have lost me here. Does that mean that both types of L8 run closed loop, even the one that is used on cars without the cat??
Old 19-10-2005, 10:44 AM
CosRush
CosRush's Avatar
No......
The Red Top 4x4 engine used the Red Label WD048 where the system basically operates as the Red Top 2wd engine albeit with the ECU differences of the L8, but the Green Label WD048 used the Closed loop addition within the Ecu and the addition of the Lambda on the exhaust.
So to be clear, Green label Ecu will run closed loop in conjunction with the Lambda (and has previously unanswered possibly the loom too), whereas the Red Label WD048 runs without as standard as the Lambda in not enabled.
Stu@Msd can add the additional Mod to make the Red Label Ecu run closed loop if you are stuck with a red Label ecu.
Hope that helps.
JK12
33
26-04-2021 12:09 PM
TPM961
15-01-2018 10:50 AM
DixieTheKid
14-09-2015 09:04 PM
tib2220
14-09-2015 12:33 PM
marky_g
12-09-2015 04:26 PM
Quick Reply: ecu change from l6 to l8
