Series 2 cutting out - help needed!
Old Oct 3, 2005 | 12:53 PM
CARL B RST's Avatar
CARL B RST
Default Series 2 cutting out - help needed!
A few weeks ago my rs turbo started playing up - I put my foot down in 3rd, and it cut out at about 3 1/2 thousand revs.
After a couple of minutes it started again but since then it has done it a number of times whilst stationary, and decellerating etc, so there seems to be no patturn to when it does it. It's now starting to happen more frequently, and is getting on my tits a bit, so I wondered if anyone had any ideas.
It also takes several minutes to start if the engine gets warm and I switch off and go to start it shortly after (eg when getting petrol). Has been doing this for quite a long tome, but thought it was a minor problem at the time.
The fuel pump relay appears to be ok, and you can hear the fuel pump surge when you turn the ignition on. Some people have suggested that the distributor might be on the way out
Any advise would be appreciated, as I dont particularly want to start throwing money at the car if I'm replacing the wrong bits!
Old Oct 3, 2005 | 12:55 PM
GrimmeRS2K's Avatar
GrimmeRS2K
i reckon the dizzy mate, a common problem on rst's
Old Oct 3, 2005 | 12:57 PM
CARL B RST's Avatar
CARL B RST
Is there a way of testing it?
Old Oct 6, 2005 | 09:36 PM
rsturbotim's Avatar
rsturbotim
having the same problem with mine,random cutout,not starting sometimes when warm starter turning really slow first 2/3 secs when warm thought it might be dicky starter for awkward warm start but clueless as to cutting out
Old Oct 6, 2005 | 10:56 PM
Big-J's Avatar
Big-J
Steer fi the rear!
having the same bloody problem with mine. look a right tit at the petrol station! starts fine with a bump.
Old Oct 7, 2005 | 11:56 AM
CARL B RST's Avatar
CARL B RST
I can sympathise!
I'm gonna try and test a few things at the weekend - ie get it warm so it wont start and see if i get a spark etc. will let you know what happens
Old Oct 7, 2005 | 11:58 AM
Big-J's Avatar
Big-J
Steer fi the rear!
done this with mine too. was sparking. thought it was maybe flooding, but took the plugs out n didnt seem to be
Old Oct 7, 2005 | 11:33 PM
rsturbotim's Avatar
rsturbotim
let us know what happens mate feel a right fool at filling stations asking for a push
Old Oct 9, 2005 | 09:40 AM
louie1's Avatar
louie1
hi lads a slow starting problem can be caused by a stainless steel exhaust as this sits closer to the starter motor and heats it up i put a xr2i starter on my old turbo as it is shorter and didn't suffer from the heat as much.
i will consult my brother about non starting though as this all sounds familiar but cant remember if it was dizzy or sensor will return to this for you later all the best.
Old Oct 10, 2005 | 04:11 PM
CARL B RST's Avatar
CARL B RST
Seemed to be sparking ok at the weekend, and likewise the plugs were dry, so doesn't seem to be flooding. My dad wondered if it could be to do with one of the sensors, but doesn't know enough about them to know which one etc.
I've been trying to get hold of the RS owners club registrar for series 2's, as he offers free technical advise, but sadly no joy as yet
As for the slow starter, would this cause it to not start at all, or would it just take ages?
Old Oct 10, 2005 | 07:15 PM
Big-J's Avatar
Big-J
Steer fi the rear!
i spoke to my cousin and the mechanics at my uncles garage, and they said it wont be the starter. they said mine was turning over fine. got a new dizzy coming now, so we'll see if that makes a difference.
Old Oct 10, 2005 | 09:20 PM
mathewwebber's Avatar
mathewwebber
I had a similar problem on my 1.6i orion, turned out to be a clogged fuel filter the first time, nice cheap fix. then it was damp in the dizzy
Old Oct 10, 2005 | 09:23 PM
Big-J's Avatar
Big-J
Steer fi the rear!
have to admit, i have been thinking along the lines of fuel problems. changed the fuel pump relay a couple of weeks ago, but still doing the same...
Old Oct 10, 2005 | 09:41 PM
mathewwebber
My 1.6i was an MFi so could well be a similar problem if your turbo is as well. wont hurt swapping the fuel filter either, well unless its new which would make that a pointless task
good luck with it anyway
Old Oct 10, 2005 | 09:57 PM
rsturbotim's Avatar
rsturbotim
changed my fuel filter but still no better
Old Oct 11, 2005 | 12:10 PM
CARL B RST's Avatar
CARL B RST
Put a new fuel filter on when we serviced it about two months ago, so don't think it will be that, but could be something to do with the pump i suppose.
Will be interesting to see if the new dizzy sorts it out for you, ill keep me fingers crossed!
Just as a matter of interest, has yours ever cut out? How long has it not been starting when its warm?
Old Oct 11, 2005 | 12:42 PM
Big-J's Avatar
Big-J
Steer fi the rear!
yeah, on the motorway once, dropped her into third and floored it........nothing
that was just a couple of weeks ago. other than that its just when i'm starting it from warm. been like this since i got it about a month or so ago. have no confidence in it these days, so hardly using it
Old Oct 11, 2005 | 01:01 PM
CARL B RST's Avatar
CARL B RST
i know what you mean, but sadly, its my only car.
Having said that, i drove to leicester and back a few weeks ago, and it was fine all the way there, but the following day it cut out about four times in the space of a few miles...
bloody cars!
Old Oct 11, 2005 | 11:19 PM
GrimmeRS2K's Avatar
GrimmeRS2K
your new dizzy should solve your problem
Old Oct 13, 2005 | 12:28 AM
escortlad's Avatar
escortlad
i have this kind of problem too,in 3 months its just cut out 3 times but cant see a pattern it just does it some times,the last time it did it i was changing up a gear,the other two times 1 it was idleing the other i was goin 10mph!
Old Oct 14, 2005 | 08:20 PM
CARL B RST's Avatar
CARL B RST
has it started straight away when it has cut out, or does it take a little while? have you had the warm starting problem aswell?
Old Oct 15, 2005 | 12:39 AM
escortlad's Avatar
escortlad
starts fine after and no warm starting problem
Old Oct 15, 2005 | 10:09 AM
Big-J's Avatar
Big-J
Steer fi the rear!
sounds like a different problem from mine matey
Old Oct 15, 2005 | 07:29 PM
CARL B RST's Avatar
CARL B RST
have you got the new dizzy on there yet? if so, has it cut out since?
not that i want to talk it up, but it hasnt cut out for about two weeks now. cant think the problem's sorted tho, cos we havent actually changed anything yet!
Old Oct 15, 2005 | 07:51 PM
Big-J's Avatar
Big-J
Steer fi the rear!
going to work on it tomorrow, so i'll get it on then. should also get it out for a run and see what happens. fingers crossed. thinking about selling it though....
Old Oct 16, 2005 | 04:58 PM
James Raby's Avatar
James Raby
Carl, if you need anything to try - ring me (got many parts u can try)
Old Oct 17, 2005 | 01:01 PM
CARL B RST's Avatar
CARL B RST
cheers james, ill give you a call tonight.
Old Oct 20, 2005 | 05:42 PM
Al1exx's Avatar
Al1exx
Alright lads,
Sorry to butt in, but my S1 has a very similar problem - it always cuts out turning right round roundabouts. Had to push the thing a mile home today wi my bro. No matter what speed etc it just dies, horrible feeling cos I can be doing 40 or 50 and I just feel it lurch, throttle does nothing, dropping down through the gears does nothing, and it just grinds to a halt
Makes me want to take a match to it
Old Oct 20, 2005 | 09:53 PM
icecossie's Avatar
icecossie
Default I had just posted a message for same problem
My cossie has started doing this in the last couple of days. When i start it from warm it cutts off after couple of minutes of running and this could be when driving or stationary or what ever. Then it takes me a minute or two to get it started again. I have read this thread and you have given me a lot to check out thanx but has anyone actually solved the problem yet? This is obviously common.
Old Oct 25, 2005 | 05:52 PM
SafeChav's Avatar
SafeChav
lot of replies on here bit taxing to read them all so sorry if someone has suggested it already.
this is for your warm start problem....check the fuel pressure is being maintained, literally whip off the air filter, and gently push the metering flap down, if it flies down and springs back rapidly theres no fuel pressure, if there is pressure it will rise steadily and smoothly. Probably best doing it in the morning after its sat for a while......and if your not sure if there is pressure there, run it turn it off and compare how the flap moves then to how it did before, u'll soon get an idea of what i mean.
Mine did the same, started reasonably, not the best but reasonably cold, then like u say, stop in the petrol station, come back out and 3 minutes worth of cranking later and a lot of and it started again, while everyone is looking over muttering "look at that crappy A reg cabriolet that wont start"
And as for your cuting out...........likely to be the dizzy......mines on its way out although my only symptoms are the occasional spectacular back firing under load makes everyone jump and look ha ha but can get annoying when ur trying to whip ass.
about the only way to do it is to get another dizzy.....
if any of this is the same as your problem let me know and ill help u fault find
Old Oct 28, 2005 | 11:05 AM
Rs Adz's Avatar
Rs Adz
I have an xr2i H reg and this morning my car cut out on me with no warning and had to push it home good job i was just down the road but i cant get it to start again it sounds as if it wants to start but nothing happens any suggestions would be a big help as this is my only car.
Fordmad!
Sep 26, 2015 05:24 PM
Bailes1992
Aug 16, 2015 07:14 PM
track.focus'd
Aug 12, 2015 05:53 PM
col93saphcos
Aug 7, 2015 03:21 PM
dlwarrior
Aug 5, 2015 10:19 AM
