cvh head??? PLEASE HELP
Old Oct 1, 2005 | 04:04 PM
jonnyturbo's Avatar
jonnyturbo
Default cvh head??? PLEASE HELP
can you swap a lean burn cylinder head for a hemi type without changing the pistons etc?
Old Oct 1, 2005 | 05:40 PM
SafeChav's Avatar
SafeChav
indeed you can but no-ones saying what it will run like, massive difference to the compression ratio...
Old Oct 1, 2005 | 05:43 PM
jonnyturbo's Avatar
jonnyturbo
what would you need to do to sort it?
Old Oct 1, 2005 | 05:46 PM
SafeChav's Avatar
SafeChav
that unfortunately i do not know the answer to i havent messed around with carb engines that much. Just out of interest what engine is this on, i see you have a S2 cabby turbo?????
Old Oct 1, 2005 | 05:56 PM
jonnyturbo's Avatar
jonnyturbo
my cabby isnt a turbo. its the carb model. with a lean burn head and ive got a hemi type stage 2 head i want 2 put on. i thought my head was the hemi type but i got it wrong.
Old Oct 1, 2005 | 06:04 PM
SafeChav's Avatar
SafeChav
ahhh right yeah i saw the turbo bit on the wrong side lol
yeah all the later carb CVH's have leanburn, im not too sure what the pistons in the earlier type are like?
on the other hand if you want to go up to a better engine ive got an XR3i engine, coming out of an orion some old boy has owned, just done a bit of a service on it and its running as good as they get, no smoking or anything, and does 120 with ease and plenty more throttle to go, if your interested?
not much u can do to the carb models
what size is yours aswell 1.6 or 1.4?
Old Oct 1, 2005 | 06:09 PM
jonnyturbo's Avatar
jonnyturbo
its the 1.6. and i have the stage 2 head with kent cam in it(though it is the hemi type) and i also have a pair of twin 40s to go on so couple all that with the freeflow exhaust and piperx airfilter i should have a good 135-140bhp. trouble is tryin to make that head work lol
Old Oct 1, 2005 | 06:12 PM
jonnyturbo's Avatar
jonnyturbo
forgot to mention its the later 88 hemi type head that i have, made for carbs but pretty rare apparently, serial code starts with D88SM6090
Old Oct 1, 2005 | 06:15 PM
SafeChav's Avatar
SafeChav
why the hemi heads are the better ones. better flow rates aswell. u got any local scrap yards near u? if i were u i would rip the head off one n hav a peak at what pistons they have.
yeah the 88 head allegedly is a rare find, although there is no difference between that and a 81 hemi off an injection, the only difference they are thought to have if any is the valve seats. where did u get the head from as thats the head that was fitted to carb models that didnt go leanburn
Old Oct 1, 2005 | 06:21 PM
jonnyturbo's Avatar
jonnyturbo
i know hemi heads are better. that was cos i thought mine was a hemi but its a lean burn. so obviously i wanna use the new hemi head cos its ported and polished with good cam. just wanna know how 2 make it work on my engine
Old Oct 2, 2005 | 09:06 AM
jonnyturbo's Avatar
jonnyturbo
bttt
Old Oct 2, 2005 | 05:05 PM
jonnyturbo's Avatar
jonnyturbo
any1 know?
Old Oct 3, 2005 | 07:46 AM
JesseT's Avatar
JesseT
A simple answer:
Yes, you need to replace the pistons aswell.
Old Oct 3, 2005 | 02:51 PM
jonnyturbo's Avatar
jonnyturbo
is it just the pistons i need to change? will everything else work ok then?
Old Oct 4, 2005 | 11:18 AM
JesseT's Avatar
JesseT
It's only the pistons and the head.
Old Oct 5, 2005 | 11:12 AM
Marc97's Avatar
Marc97
A Hemi head will fit AND RUN on a lean burn block, I've done it (XR2i head)!
The pistons are different in the way that a lean burn only has 1 high spot per piston, a hemi has 2 theoretically losing compression (how much I don't know) but this can be sorted by a: replacing the pistons or b: skimming the head.
You say you have a high lift cam, when the head is fitted and the cam belt is on, turn the engine by hand to make sure you don't have any valve contact before starting.
Old Oct 5, 2005 | 02:47 PM
jonnyturbo's Avatar
jonnyturbo
thanks marc. most positive news I've heard in a while. the head is a ford one thats been ported and polished etc so i reckon its probably been skimmed. so as long as there is no valve contact you reckon it should run fine?
Old Oct 8, 2005 | 05:03 PM
Marc97's Avatar
Marc97
Yup, no probs mate, I don't even have any trouble with hot starting!!!!
Old Oct 9, 2005 | 12:28 AM
jonnyturbo's Avatar
jonnyturbo
did you change your pistons? or are they the lean burn ones?
Old Oct 9, 2005 | 11:25 AM
Marc97's Avatar
Marc97
I kept the original lean burn pistons which theoretically loses a little bit of compression BUT for a standard engine it is still very fast and won a championship 1st time out
Old Oct 9, 2005 | 03:23 PM
jonnyturbo's Avatar
jonnyturbo
cool. im just gonna slap it on then, cos should make up for loss of compression with the bigger ports and cam and twin 40s
Old Oct 10, 2005 | 04:17 PM
Marc97's Avatar
Marc97
Go for it.
Time to start a new gearbox thread now
Old Sep 20, 2019 | 08:39 PM
David Jursons's Avatar
David Jursons
Default Dave j
ive got a lean burn engine in mine. I’ve took the head off and put a rs turbo hemi head on. That’s been ported and polished. Sodium filled valves. I’ve put a piper 285c cam in running on twin 40s and a xr3i exhaust.
Was a bit shocked at the outcome as only made 104bhp was expecting a lot more. Not sure if it’s the head or not. Tempted to get the standard lean burn head ported and put that on and try it.
Old Sep 30, 2019 | 03:39 PM
FloydH's Avatar
FloydH
Might be the exhaust? A 4-branch & straight-thru makes loads of difference, or even just the 4-branch (or 4-2-1)
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
