valves and pistons
Old Jul 1, 2004 | 07:28 AM
rossatom2's Avatar
rossatom2
Default valves and pistons
i'n investigating a noise in my 2wd cossie engine, is it possible for the valves to be tapping the pistons when the engine is running even though the engine turns easy anf free when turned by hand?
cheers 4 any help
Old Jul 1, 2004 | 09:53 AM
Dave McB's Avatar
Dave McB
could it not just be piston slap youre hearing??...
Old Jul 1, 2004 | 06:03 PM
Alvyn's Avatar
Alvyn
Default Re: valves and pistons
cheers 4 any help
yes they can if timed up wrongly as they can clip the tops of the pistons on hard reving when timed up correctly if that makes sense to you!
Old Jul 1, 2004 | 07:26 PM
rossatom2's Avatar
rossatom2
yes but the timing marks are lined up perfect. and i even put a different whole bottom end in and it'a still doing it
Old Jul 1, 2004 | 08:28 PM
Alvyn's Avatar
Alvyn
Is it making the same noise that your OLD engine was making then SO it would point to the head then(if thats the same one you using) if it's hitting the pistons,has the head been skimmed TOO much!
Old Jul 1, 2004 | 09:04 PM
rossatom2's Avatar
rossatom2
well the head is new too, the noise came with the old engine,then i changed the head and it still there then i changed the whole bottom end and the noise still there. there is not one bit of the original engine left. but tthe noise still there.
Old Jul 1, 2004 | 09:13 PM
Azrael's Avatar
Azrael
Maybe it's not the engine??????
Old Jul 1, 2004 | 09:15 PM
rossatom2's Avatar
rossatom2
it has to be something to do with the timing but who the hell knows what
Old Jul 1, 2004 | 10:18 PM
Alvyn's Avatar
Alvyn
Is it timed like this?
1: cam pulleys should be pointing towards each other.
2:rotor arm pointing towards the pointer for number 1 cylinder in the dissy.
3:crank pulley use the lug nearest the "V" (1 to the left) on the crank pulley.
Old Jul 1, 2004 | 11:01 PM
rossatom2's Avatar
rossatom2
yep
Old Jul 2, 2004 | 06:52 AM
rossatom2's Avatar
rossatom2
are the cams different to each other? ie inlet and outlet, what would happen if i got them the wrong way round?
Old Jul 2, 2004 | 09:12 PM
Alvyn's Avatar
Alvyn
cams are different m8!
Old Jul 3, 2004 | 02:20 AM
Stu @ M Developments's Avatar
PassionFords Creator
The inlet cam has a groove around the bearings.
Old Jul 3, 2004 | 11:51 AM
rossatom2's Avatar
rossatom2
nope i got the cams the right way round, i'm wondering if bothe heads had been skimmed and i not known about it..how can you tell a skimmed head??
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
deathrider666
Sep 28, 2015 06:12 PM
coscor86
Sep 20, 2015 01:21 PM
