Boost gauge readings ??????
Old Aug 27, 2005 | 09:29 PM
tosh's Avatar
tosh
Default Boost gauge readings ??????
Just a quick question if anyone can help?
I've fitted a boost gauge to a stage 2 sapph and on idle the vacuum (negative pressure) is reading 30 inHg is this Ok! or is there something wrong, I'm sure that I have read somewhere before that most gauges read at about 15 to 16 at idle.
Old Aug 28, 2005 | 11:11 AM
cossiegreg1's Avatar
cossiegreg1
yeah my gauge reads 15 on idle but i dont know about if its ok reading 30 sorry m8
Old Aug 28, 2005 | 04:04 PM
rsjohn's Avatar
rsjohn
On most of my turbo rsts and cosworths the needle has been on 8-10 neg on boost gauge.
Can you post a pic of it pleased?
john
Old Aug 28, 2005 | 06:58 PM
tosh's Avatar
tosh
john
Here's a photo of it you asked for mate its made by AUTO GAUGE!!!
Old Aug 28, 2005 | 07:04 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
think it should sit about 15or there about it has on my last 2 s2s but maybe differant for cos,hope u get it fixed,tommy
Old Aug 28, 2005 | 09:02 PM
rsjohn's Avatar
rsjohn
I meant a pic of it in your car so i can see what needle is pointing to!!!!
john
Old Aug 30, 2005 | 08:50 PM
tosh's Avatar
tosh
[quote="rsjohn"]I meant a pic of it in your car so i can see what needle is pointing to!!!!
Sorry no can do John! but to be honest the photo of it in the car would look the same as ubove picture but the needle would be on the 30 inHg.
Also had a play around with it today and noticed that when I pull the vacuum/air hose off from the top of the Dump valve the boost gauge then reads 15 inHg, if anyone has any more ideas! as to what the problem could be please let me know.
CHEERS!!!!
Old Aug 30, 2005 | 08:53 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
what dose it sit at with engine off
Old Aug 30, 2005 | 09:01 PM
tosh's Avatar
tosh
When I turn the engine off the needle goes back to just under the zero, do you know what governs the vacuum hose preshure???
Old Aug 30, 2005 | 10:32 PM
rsjohn's Avatar
rsjohn
You have got the boost pipe connected wrong on your manifold then?
Can you tell me how you have the pipes connected for the DV, boost gauge and fuel pressure please?
john
Old Aug 31, 2005 | 05:31 AM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
i think same as john pipe wrong on inlet check all pipes
Old Aug 31, 2005 | 08:26 AM
Dave Henshall's Avatar
Dave Henshall
mine idles at -0.6 bar gauge = 20 inHG and that with no air leaks or dump valve.
Old Aug 31, 2005 | 11:38 AM
tosh's Avatar
tosh
OK lets see if I can explain??
If you think of the outlets on the plenum as North _ East _ South _ West
Map sensor goes to North
the fuel reg goes to East
South is blanked off from the old breather
West goes to the Dump Valve which I have Teed off of close to the plenum for the feed to the Boost gauge.
Is this correct???
Old Aug 31, 2005 | 01:05 PM
Dave Henshall
makes no difference really, all are into the same plennum, they are just there so each one can be directly connected, the order they are piped in makes no difference.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
