HELP. Fuel pump problem in sierra cosworth
can anyone tell me,which relay switch or fuse is for the fuel pump is it inside the car or under bonnet . my fuel pump wont work when i turn on the ignition its not the pump itself as i put power straight to it and it works.tried all fuses and none seem to be blown.where else could the problem be any help please . or a small diagram of the fuse box might help.
Thanks john
Thanks john
Have you checked the fuel cut off switch?
Maybe there's a problem with that.
A mate of mine had the same problem with his car neither of us could find the fault. Checked the relay and fuses nothing wrong with them.
kosienutter
31
22-08-2015 09:55 AM
Stu @ M Developments
41
21-08-2015 06:47 AM
155lee
14-08-2015 11:21 AM
CabrioTurbo
01-08-2015 11:04 AM
