Gearbox problems
Old Aug 3, 2005 | 05:53 PM
haz87's Avatar
haz87
Default Gearbox problems
Right since ive refitted everything into my shell i havent managed to get into 1st or second. I never removed the gear box, however i did remove the gearstick& linkage(as one) from the gearbox. I simply bolted it all back together once everything was in but it will only find 3/4/5/Reverse....
Any ideas? its an IB5 box (i think) Series 2 rst gbox with lsd if that makes it easier,lol. Was working fine before. Advice/ help appreciated as i dont fancy pulling away in 3rd when its running
Old Aug 3, 2005 | 07:51 PM
haz87's Avatar
haz87
anyone
Old Aug 3, 2005 | 08:24 PM
antony215's Avatar
antony215
Escort Rs Turbo
Undo the linkage put the gear stick in forth then pull the rod from the gearbox back till it meets the linkage and connect it up and see if that works it's more of a trail and error thing till you get all the gears
Old Aug 3, 2005 | 08:48 PM
haz87's Avatar
haz87
right so basically the rod that comes from the gearstick i need to push/n pull till i feel it connect to the linkage? is that right?
Old Aug 4, 2005 | 07:56 AM
mart.rs's Avatar
mart.rs
mate im from colchester where abouts are you and i will come round and show you,im only up at mile end well its actually called myland,im free late tonite after ive fitted me clutch ratchet on mine!
TPM961
Jan 15, 2018 10:50 AM
Flateric_2002
Sep 15, 2015 08:41 AM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
fordfiestamk3
Sep 11, 2015 12:52 PM
gingeRS
Sep 4, 2015 06:29 PM
