power question rst
Old Jul 18, 2005 | 06:27 PM
rsturbotim's Avatar
rsturbotim
Default power question rst
does anyone know how much power i can get out of my s2 rst before i have to upgrade my internals cheers
Old Jul 19, 2005 | 10:53 AM
mart.rs's Avatar
mart.rs
well you can make 170bhp by a simple chip upgrade and -31 actuator to hold the boost,then maybe either a kent or piper cam for longer duration( the time the inlet valves are open) and then a uprated intercooler like a pace 50% larger one or the new front mounted ones with one or two fans at this point you should see around 190ish,after this you will want to go for a hybrid turbo as the original t3 will stop at 16psi you will see just over 200bhp , i would then strongly advise you then start looking at low compression pistons arp con rod bolts etc........
Old Jul 19, 2005 | 07:29 PM
rsturbotim's Avatar
rsturbotim
thanks for that was just wanting to know for piece of mind because its already got minor mods exhaust,filter,bleed valve etc... not had chance to see any rollers yet though.
Old Jul 20, 2005 | 09:29 AM
mart.rs's Avatar
mart.rs
if i were you tho id get rid of that bleed valve there a bit sketchy
JK12
33
Apr 26, 2021 12:09 PM
`spotty
Sep 25, 2015 11:41 PM
liamT74
Sep 23, 2015 10:24 PM
Billy_RS
Sep 13, 2015 04:17 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
