cosworth 2wd misfire help required
Just rebuilt the engine in the cossie have done 600 miles all of a sudden has developed a missfire
It only happens under load and Iam not driving the car too hard as I have to run it in a while
So far I put new plugs in checked cap leads coil and cleaned crank position sensor
The only other help is that it runs fine while it is cold
any help apreciated
Si
any help apreciated
Si
When u say under load we talkin on boost or off?!
Mine hand an intermittent miss which hopefully, ive traced to being a leak on the inlet manifold!! Only just got her running today so wont know till ive driven her for a while!!!
Other things it could be is the CPS either damaged or gunked up, TPS, water sensor as said or air leak on inlet. Or realated 2 something on the ignition, as said coil/leads or poss the phase senor in dizzy etc etc etc!!
FlashRS
13
31-08-2015 06:02 PM
yawiejon
15
09-08-2015 06:36 PM
