Overheating lile a b***h
Old May 28, 2005 | 08:22 AM
kingpin09's Avatar
kingpin09
Default Overheating lile a b***h
Hi, i know overheating is a common problem with erst, unfortunately mine seems to be overly occurent. I had it taken to the garage twice but the problem still remains. Apparently the radiator works for a little while but then all of a sudden i see that the temperature needle is at maximum and the fan has cut out, resulting in the internal heater and indicators cutting out (i have been told that they are all on the same relay) Im hoping someone can help me and tell me why the fuse and the relay get burnt.
Thanks in advance
Old May 30, 2005 | 01:15 AM
Escort.Cosworth's Avatar
Escort.Cosworth
You solve the problem mate?
Why not just put a switch in car and run the fan off that so you can have the fan on when ever you want
Old May 30, 2005 | 01:28 AM
SS1's Avatar
SS1
try a back flush into the system with a hose pipe
Old May 30, 2005 | 11:25 AM
kingpin09's Avatar
kingpin09
Thanks fellas, much appreciation...none of thes ideas crossed my mind. I did about 100 miles this weekend and it stood strong, fan was kicking in. Im just waiting for the hot weather to kick in. Im gonna give both ideas a good look at....
Old May 30, 2005 | 12:00 PM
Rs1's Avatar
Rs1
Tbh the frst's are really bad for it,a m8 of mine used to drive round with his heater on hot and the internal fans going like the clappers in the summer,he used to have to hang out the window as it got so hot in the car. A system flush would be a good idea to remove any crap and a over ride fan switch for use in traffic is wise too. You'll notice once you get moving the temp stays reasonable,airflow is key with rsts overheating,maybe a bumper mod in order to get more air to the rad perhaps? There is a cosmetic issue then ofcourse.
Old May 30, 2005 | 01:22 PM
bud-weis's Avatar
bud-weis
Football Cwazy
surely it's down to a knackered component somewhere in the system. they didn't leave the factory with overheating probs did they? replace the thermostat, give the system a good flush and make sure there isn't any air in the system, might even be worth buying a new rad. unless your engine is heavily modded with big boost it should run as cool as a standard car. if it was me i would remove all the hoses to and just double check things, refill with antifreeze/summer coolant and hopefully you'll be cooler than an eskimo's arsecheeks
Old Jun 1, 2005 | 09:11 PM
kingpin09's Avatar
kingpin09
lol at the last post...im in agreement, im gonna have the car head out to janno at oddkiddcreations to have a maticulous look at the whole system. For the time being the system is sweet...when the sun comes out though its another q..
Old Jun 1, 2005 | 10:50 PM
bud-weis's Avatar
bud-weis
Football Cwazy
good lad!! jano knows his stuff
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
Ade
Feb 8, 2007 05:11 PM
kurdt5
Jul 17, 2006 03:01 PM
fiestaturbo1984
Feb 19, 2006 03:51 PM
woodz77
13
Nov 6, 2005 03:02 PM
