Modifying in reverse, can anyone help
Old Jun 1, 2005 | 08:16 PM
niceRST's Avatar
niceRST
Default Modifying in reverse, can anyone help
I have a 187 bhp ERST and it might sound strange but i want to get it as standard as possible. Its chipped so i guess the first step is to get 2 standard ecu's. I may be wrong but do any of you have any ideas to get me going.
CheeRS
Old Jun 1, 2005 | 11:00 PM
bud-weis's Avatar
bud-weis
Football Cwazy
yep you wanna replace the silver ecu for a standard one of the same type ( they have different logos on the front with coloured squares or hearts and diamonds or summat ) the other ecu is the black fuel ecu but i would doubt very much if it has been modded in any way so that should be ok to keep. next you wanna turn the boost back down to 7 psi or thereabouts and remove any dodgy bleed valves if you have one. itheres a good chance it has a dump valve too so if it has remove this and replace the boost hose it's fitted in for an un-cut one or blank off the t-piece. you'll possibly have an induction kit fitted to it too so you'll want to get a standard airbox off e-bay or summat and fit that. might wanna replace the cam and followers too cos it may have a high lift cam fitted to achieve 187 bhp. a pic of your engine bay would help too
DAZZER
Sep 30, 2015 08:43 PM
cameron2
Sep 23, 2015 06:31 PM
cameron2
Sep 20, 2015 04:30 PM
The Enigma
Sep 12, 2015 10:12 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
