ERST Running Problems
Old May 20, 2005 | 07:56 AM
originalcabbie's Avatar
originalcabbie
Default ERST Running Problems
Guys,
I am hoping someone out there can give me some help. I recently brought an RS Turbo Cabbie with a fooked engine. I rebuilt the bottom end with new piston rings and big end bearings. I had the head cleaned and skimmed (the previous skim was awful) the valve guides replaced, the valves reseated and new valve stem oil seals.
I put the engine back together and it has never run fine since. Recently I have managed to get the car to start on the button and idle but until you get up on the turbo the car coughs and splutters. It seems like a timing problem but I have checked the cam belt and I havnt jumped a tooth and twidling the distributor seems to make it worse. When driving its even more hesitant.
I have also had problems with new spark plugs as the only ones that seem to work are the old ones even tho I brought the same ones from my local store.
I know the guy that had the car before me was running a chip so I had to adjust the fueling back to where it should be but in the end I had to turn the fuelling down almost two turns.
Please help me, Please.
Rob
Old May 20, 2005 | 01:27 PM
davidnormanuk's Avatar
davidnormanuk
The timing should 12 degrees before TDC on idle with the vacume pipe blocked off. I'd start from there and get your fuelling checked. When I did my conversion I blew the engine due to poor fuelling. Which had brand new pistons in. Expensive mistake.
This link is a good way to get it running something like to get it to a garage to set the mixtures set up properly.
http://www.escortrsturbo.co.uk/commu...showtopic=2429
Hope this helps
Dave
Old May 20, 2005 | 11:12 PM
GrimmeRS2K's Avatar
GrimmeRS2K
Default Re: ERST Running Problems
Originally Posted by originalcabbie
Guys,
Rob
I thought turbo heads are not meant to be to skimmed?
Old May 23, 2005 | 07:39 AM
davidnormanuk
i think you can get away with skimming them once or twice. I've had to buy a spacer plate for mine to compensate for it.
Old May 23, 2005 | 08:36 AM
db's Avatar
db
Get the fuelling back to standard settings, if necessary with help of a tuner.
Are you using a std ECU? Try changing that with one of which you know it's working properly. That rules out ECU problems.
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
Ellsa
Aug 9, 2015 07:03 PM
