smoking cosworth
Old May 16, 2005 | 05:37 PM
running rough's Avatar
running rough
Default smoking cosworth
hello im new to this site but have only recently been going to the pf meets at the bull at arborfield. i own a g plate sierra cosworth and recently done an engine re-build but recently noticed that the car smokes on idle. the other problem is that it isnt all the time.only after a driving a bit hard. it doesnt seem to smoke when driving tho any help would be much appreciated!
Old May 16, 2005 | 07:13 PM
Daveyraveygravy's Avatar
Daveyraveygravy
what colour is it & how much comes out?
Old May 16, 2005 | 08:53 PM
running rough
its oily smoke. i wasnt sure if it was the turbo. i dont want to buy one if that aint the problem.
Old May 17, 2005 | 05:17 AM
Azrael's Avatar
Azrael
Take off the intake hose and ehxaust and check for oil in those places. Also check how is your breather system. Is it connected to the intake? If not those two you probably have to go to somebody who build it and kill him
Old May 18, 2005 | 08:38 AM
tizzer0's Avatar
tizzer0
what azrael is saying makes senese because if the air in take is not connected properly then ur car will be starved of fresh air and will eventualy make it smoke its balls off. hope u get it sorted
Old May 18, 2005 | 11:20 AM
cossied's Avatar
cossied
Default oil
When mine did that I had overfilled the oil
Old May 18, 2005 | 09:33 PM
esccossie666's Avatar
esccossie666
dose it do it on acceleration?
its a poss u have the rings upside down or an oil ring has broken
Old May 19, 2005 | 08:53 AM
foreigneRS's Avatar
foreigneRS
Testing the future
for arguments sake, say you'd removed the top ring of 1 piston to check the clearance in the bore, and you'd put it back on upside down, would that cause a lot of smoke when revving up after being on idle?
mine does that, but does not smoke on boost or on the overrun or anything. if that is the case, would you expect it to get better as you put more miles on the engine and wear the ring in?
Old May 22, 2005 | 06:01 PM
esccossie666
unfortunately if its smoking and you have put a ring in the wrong way its not going to get better as its trying to scrape the oil up the bore instead of down it
Old May 23, 2005 | 10:50 AM
foreigneRS's Avatar
foreigneRS
Testing the future
can you get such bad smoke from just one top ring the wrong way up though?
won't the ring wear in at all? or are they so much harder than the bore?
Old May 26, 2005 | 04:19 AM
pugo's Avatar
pugo
what spec is the engine???? if its rings they will smoke when you accelerate hard, not just on idle, it might just be running a bit rich on the top end and after you have poodled it home after a good hard blast she may just be a bit sooty and thats what your seeing
find out if its definatly oil first.......whip the plugs out if they are black and oily..its fooked, if they are black and sooty, get a tuner to check the fuelling for you
rsturbo27
Sep 1, 2015 09:54 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
The Enigma
13
Aug 20, 2015 09:38 PM
Aug 14, 2015 07:29 AM
Adam-M
22
Aug 10, 2015 10:46 AM
