zetec/ cvh
Old Jun 10, 2004 | 05:40 PM
twink's Avatar
twink
Default zetec/ cvh
Hello, I have just joined passion ford.com , I drive an Escort Cosworth replica. Its a Mk 5 xr31. I am aware that you can bolt a zetec bottom end on to a cvh turbo engine. My question is can you bolt the cvh top end on to the zetec bottom end in the mk5 or is there extensive work required?
Old Jun 10, 2004 | 06:53 PM
MadMac's Avatar
MadMac
What your talking about is a ZVH conversion, which for a Mk5 xr3i would be a waste of time as the zetec 16v has the better head than the 8v CVH. And yes there is a lot of work involved if you do try it.
It would be infinately easier to find a 2.0 Zetec from a Mondie and drop that in cus you should be able to put it in without any major hassle and only really need to map the ECU and change a few of the ancillaries. Plus you can turbo it for about 2k-3k and bobs your mothers uncle you have a cossie replica that goes like one.
Old Jun 10, 2004 | 07:36 PM
Lee @ Fusion's Avatar
Lee @ Fusion
couldnt put it better myself
Old Jun 10, 2004 | 07:56 PM
MadMac's Avatar
MadMac
Why thank you, I'm glad you aprove. Thinking of Zetec conversions I'll need to have a word with you about engine mounts for a Mk4 escort as I understand you do them.
Old Jun 12, 2004 | 07:00 PM
Lee @ Fusion
???????????????????/ explain mate ,
Ford MK 4 CVH mounts fit to the zetec , notch a small amount of but thats it .
I can explain or for the price of postage ill do it for you
Old Jun 14, 2004 | 01:05 PM
MadMac's Avatar
MadMac
I thought it was all mounts would fit with the exception of the one next to the inlet manifold and you needed at specially made up one?
Or was that just me?
Old Jun 14, 2004 | 07:03 PM
Lee @ Fusion
you are right mate , the rngine mount doesnt fit straight on , but is an easy mod and costs nothing . ( except for the standard mount obviously .)
Old Jun 15, 2004 | 02:29 PM
s1 cabby's Avatar
s1 cabby
Stu what are ya goin on about its a mk5 which already has a zetec engine in it!!
mk3ste
Oct 17, 2021 10:09 AM
sridgett
13
Sep 27, 2015 06:03 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 03:19 PM
Russp
Escort Range
Sep 18, 2015 07:39 PM
