coilpack question
Old May 6, 2005 | 10:47 AM
rsrob's Avatar
rsrob
Default coilpack question
im in the middle of putting cossie management on my escort and im just wondering what is needed to run coil packs and where can i get it from ???
i already have a coil pack btw just wondered if it is a seperate loom i needed??
thanks in advance
Old May 6, 2005 | 02:21 PM
foreigneRS's Avatar
foreigneRS
Testing the future
contact stu at motorsport developments. he is working on the supply of these.
basically the ecu sends a pulse to the ignition amplifier to tell it to make the coil spark. that is normally done on a cossie 4 times per 2 crank revolutions, and the distributor sends the spark to the right cylinder.
with a coil pack, you run what is known as wasted spark. that means that a spark is sent to 2 cylinders at a time, one of which uses it, and the other doesn't (so it's wasted - apart from wearing the electrode of the spark plug ). but if you were to use the standard output from the ecu and ignition amplifier, the coil pack wouldn't know which pair of cylinders to send the spark to. so you need some extra electronics to get a signal from the ecu that is based on both the crank position sensor and the phase sensor. that signal then needs to go to 2 ignition amplifiers, or a twin amplifier, that then tells the coil pack which side to fire a spark to it's connected pair.
Old May 6, 2005 | 04:02 PM
rsrob's Avatar
rsrob
cheers mate ill give him a ring monday
Old May 7, 2005 | 10:13 AM
rsrob's Avatar
rsrob
Anybody else shed any light on the subject ?
Old May 7, 2005 | 11:49 AM
Stu @ M Developments's Avatar
PassionFords Creator
Everything you will need for the coilpack conversion itself, including teh loom can be seen here:
http://www.motorsport-developments.c...cPath=36_37_32
I presume youve already dealt with the phase sensing side of things?
Old May 7, 2005 | 09:18 PM
rsrob's Avatar
rsrob
not sure stu
i have bought a loom which was in a 2.1 zvh already so it is all ready to go in apart from this loom is running a dizzy, so i bought a coil pack and was told i needed a seperate loom
its all new to me so any help would be a big help
Old May 7, 2005 | 11:33 PM
Oh Dear...
The YB engines distributor doesnt just house the rotor and cap, it also houses and runs a very important sensor called the "Phase sensor"
Your going to have to mount this sensor in the head on your zetec ideally.. again, you can get ideas on how by looking in my webshop again and looking at the parts used to remove a YB distributor and relocate the sensor to the inlet camshaft.
Lots will have done it on here, so maybe put a post in general discussion for guidance.
Old May 8, 2005 | 12:29 AM
rsrob's Avatar
rsrob
Old May 8, 2005 | 09:58 AM
richm's Avatar
richm
here's one way.. use the standard Zetec cam sensor, add target pegs to the cam in the right positions.
Old May 8, 2005 | 10:26 AM
sailorbob's Avatar
sailorbob
Doesn't the Zetec cam sensor work off the cam lobe and pick up cylinder no. one identification only or are you using this set up to get each cylinder identified?
Old May 8, 2005 | 10:32 AM
richm's Avatar
richm
this was done to work with Marelli cosworth management, so replicates the sensor that would be in the cossie distributor.
The original Zetec sensor target is a single lobe on the cam which is no use to Marelli, so got ground off
Both systems use the cam sensor to indicate the absolute engine position in the 720 degree 4-stroke cycle.. EEC4 uses a single lobe, Marelli uses 2 lobes, but they both perform the same function.
Old May 8, 2005 | 10:43 AM
sailorbob's Avatar
sailorbob
Mmm, good stuff, gives me an idea about how to go distributerless on another engine.
Old May 8, 2005 | 04:00 PM
rsrob's Avatar
rsrob
sorry im not up on all this
it looks like i may have 1 of them sensors, could the flywheel be modified to do the same job??
as i have a modified fly wheel that has a pick up every 90 degrees ???
Old May 8, 2005 | 04:05 PM
richm's Avatar
richm
no , you need both sensors, one on the crank/flywheel like you describe to indicate RPM, and one on the cam that runs at half engine speed to indicate absolute engine position.
Old May 8, 2005 | 04:20 PM
rsrob's Avatar
rsrob
ok cheers fella
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
