Passing emissions
Old Jun 3, 2004 | 07:48 AM
italiancossie's Avatar
italiancossie
Default Passing emissions
Hi,
I am a relatively new owner of an 89 sapphire 2wd.
I have just hit the CO emissions hurdle over here in italy. My revisioni ( mot ) guy is saying that the car is running at 10% CO when it should be running at 0%
Firstly I dont believe that a non cat should be at 0% , I am guessing standard would be 2-4%. What is the standard CO on these ?
Secondly, can anyone help me on how to adjust the CO just temporarily to get past this check ?
Paul.
Old Jun 3, 2004 | 07:58 AM
markk's Avatar
markk
ecu in the panel in the passenger side dash , remove cover , and turn screw small amounts at a time , best to be done whilst emissions are being read i.e with the gas anilyser sampling , without the spec of your engine and whos map it has i it its almost impossible to say what it shoud run at , especially for european law
mark
Old Jun 3, 2004 | 08:21 AM
italiancossie
Thanks for the swift reply mark
Do I have to be careful how much I change it, can I break anything ?
Old Jun 3, 2004 | 09:30 PM
markk's Avatar
markk
yes its sensitive ,but will also adjust your fueling across the whole rev range so dont go winding it off to nothing m8 !!
Old Jun 4, 2004 | 06:38 AM
starturbo's Avatar
starturbo
Remember how much you turned it for the test and when you get outside the garage,turn it back up.
TPM961
Jan 15, 2018 10:50 AM
Bransby
Sep 21, 2015 05:29 PM
atm
Sep 7, 2015 05:39 PM
borboyous
Aug 22, 2015 11:17 AM
