2002 Ford Fusion (UK) Wipers Not Working Properly
Damn Cars
Just a quickie, I've had a look around the forum but not found an answer.
The Mrs wipers on her Fusion work ok on normal and fast but on intermittent they don't do a full cycle and stop anywhere on the screen.
Is this likely to be the relay rather than the motor as the wipers are working on the fully on setting?
Damn Cars
As expected the relay isn't labelled so took them out one at a time and it seems that a grey 70 amp one being removed stopped the wipers and fans, I assume it's the culprit.
Damn Cars
Damn Cars
Yeah I removed the smaller ones too but it still carried on in intermittent mode (as well as it can at the moment). As I said, the 70A one that stopped it knocked out the blowers too, can anyone confirm if this is definitely the one?
Moderator
the 70amp one will supply more than one circuit so if other things like blowers etc are working from that then it wont be that relay, in the drivers handbook it will tell you exactly what relay controls what circuit
Damn Cars
Looks like it was R3 I took out (ignition), the manual only specifies the front wiper fuse but none of the relays. Surely it needn't be this complicated.
TrevCos
06-01-2016 08:20 PM
Graham S1
24-12-2015 04:18 PM
TrevCos
13-12-2015 03:16 PM
