stage 3 boost psi
Old Jun 15, 2014 | 08:03 PM
tony66's Avatar
tony66
Default stage 3 boost psi
my recently bought 2wd 3 dr is a stage 3-running level 8 ecu-greens and what loooks like a blue collins actuator-it would seem to be a collins chip looking back at the history of the car[it has a lambda sensor fitted too]
the motor is a low comp 200 series engine
it runs a lot of boost-shoots off the scale at 30psi[the max the gauge reads]
cant hear it det/pink-it runs through an amal valve not a boost controller
its got an rs500 type i/c too
now i built a 2wd sapph st3 almost 2 decades ago collins chip/greens/3 bar/green top motor it ran about 25psi...
so i suppose the question is -too much boost psi on current car?
what are your thoughts
Old Jun 15, 2014 | 08:06 PM
Staffi's Avatar
Staffi
No Tony, that's fine for peak boost on a T34, i run 35 psi on mine, yes that's a lot but it's when you hold them at high revs for long periods trouble can happen
Old Jun 15, 2014 | 08:10 PM
tony66's Avatar
tony66
Default boost
ok-thanks i dont tend to hold it flat out for long anyway
cheers for the reply
Old Jun 15, 2014 | 09:23 PM
Mad_Mat's Avatar
Mad_Mat
New Owner
If its holding 30 odd psi on greens surely that would be boom time. Get it checked over to be sure.
Old Jun 16, 2014 | 09:53 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Its not too much so long as its fuelling correctly.
Get it checked on a rolling road or go up the road with an AFR gauge in it.
Old Jul 6, 2014 | 09:35 PM
tony66's Avatar
tony66
Default boost
well-i checked the actuator preload[collins blue one] and the wastegate penny arm is about 20mm or more from the actual actuator arm hole...
i"ve set it at just tighter than half hole pull over so will get it out tommorow for a wee test,whilst looking over it i noticed that the pipes to amal velve dont have any restrictor pills in them,not that they would be needed with the actuator wound that tight-is this still the method used for adjusting boost on amal controlled cosworths?
i"ve worked on turbo cars scince about 1985 and never seen an actuator wound so tight
Old Jul 8, 2014 | 05:38 PM
tony66's Avatar
tony66
Default boost
half hole gives about 22 psi-if that peak,dropping to 18/20[with amal connected]
whats the best placement for a pill>reducer amal breather,feed from turbo or to actuator,and what size generally gets used? i want around 28psi peak and that will more than likely settle at 25/6 psi
thats plenty for cutting about the roads,its wet today and 22 psi probably too much
Old Jul 9, 2014 | 10:35 AM
tony66's Avatar
tony66
Default 35psi
lol you would be as well without a wategate thats gotta be it about maxed out
Old Jul 11, 2014 | 08:16 PM
col93saphcos's Avatar
col93saphcos
Amal valve will now need jets to suit, probably try a 2mm jet think 2.5mm is standard,I used small brass screw and drilled hole down centre,
Col
Old Jul 11, 2014 | 09:49 PM
tony66's Avatar
tony66
Default boost
thanks for that-bumper off repairing the nearside bracket at the moment,once its back on i will go full hole preload on the actuator and see where/what to do
not looking for the fastest cossie in the world,dont want to stress it
edited to add one hole gave me 28psi held -do me nicely
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
Russ Payne
Sep 25, 2015 08:29 PM
