Matching ecu to engine no.
Old May 24, 2014 | 08:58 AM
Robbieh58's Avatar
Robbieh58
Default Matching ecu to engine no.
Hi, this might be a stupid question, I won an rs turbo engine on ebay to put in a mk2 fiesta but still need an ecu! Obviously want to get the right one! How do I get the information from the engine number? Cheers! Bout to be a simple question!
Old May 24, 2014 | 01:09 PM
RSmark84's Avatar
RSmark84
What RS turbo engine is it?
Old May 24, 2014 | 04:28 PM
Robbieh58's Avatar
Robbieh58
@RSmark84 from an escort mate, judging from the bumpers that we're laying about in the garage I'm guessing around an f reg?
Old May 24, 2014 | 08:36 PM
RSmark84's Avatar
RSmark84
F reg, So you'll want I believe the ECU with red,white and black squares. Not sure on order?
Dont forget you'll need the other ECU as well.
Does the inlet manifold have the knock sensor? will be close to the vacuum for the brake servo outlet.
Old May 24, 2014 | 08:43 PM
Robbieh58's Avatar
Robbieh58
Will check it out tomorrow mate as it's sitting in the garage, will try post a picture if it helps? Cheers for the help mate!
Old May 24, 2014 | 08:49 PM
Robbieh58's Avatar
Robbieh58
The engines going into a mk2 fiesta, so with the electrics think I'm going to be asking a few questions on the site, or will be getting an auto electrician on the case
Old May 25, 2014 | 05:55 PM
RSmark84's Avatar
RSmark84
Yes post a pic of the engine. The Fiesta got an external fuel pump?
big_Rad
Sep 15, 2017 09:36 AM
3drRich
Sep 13, 2015 07:32 PM
Porplus12
Sep 10, 2015 07:20 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
