Boost Problem With S2
Old Mar 27, 2005 | 03:08 PM
Andrew's Avatar
Andrew
Default Boost Problem With S2
Hi there, im new to the turbo scene.
I have a S2 ERT totally std, apart from a dump valve and samco's (boost pipes).
I have just started to notice when i put my foot down in fourth the turbo starts to wind up. Comes on boost get a little push back in my seat feel then the boost just feels like it slopes off, and the sensation goes.
I can just about feel it in the other gears but 4th seems most popular.
I hope someone can help. I have a feeling the samco from the metering unit to the turbo is a little kinked? could that be the problem?
Cheers for your help
Old Mar 28, 2005 | 03:00 PM
K18NEO's Avatar
K18NEO
check for air leaks because the boost is fluctuating. I had this problem, i boosted at 10psi and dropped down to 6psi. Mine ended up to be a dead actuator, in which id say to you, take it somewhere unless capable yourself, wipp it off and see whether you can physically pull it out.. chances are you'll need a new one or a cossie one. -31 actuator. There £60ish quid, id suggest that, but before you do, check all hoses, air leaks, and gubile clips for gaps ... if you cant see nowt, try the actuator.
JK12
33
Apr 26, 2021 12:09 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
