xr3i Lost 5th gear
Old Feb 2, 2014 | 09:40 AM
Roberto_98's Avatar
Roberto_98
How ye lads
Default xr3i Lost 5th gear
Well everybody. My car's been off the road a while but soon I'm going to be stuck into it again. One of the reasons I stopped driving it was because the last time I did I was driving down the motorway and it jumped out of 5th gear. Wouldn't stay in 5th gear so drove home in 4th. I got home and dipped the gearbox oil to find no level at all registering on the stick. I measured according to the haynes. The oil was last changed about 3 years previous with not too much mileage done. Way less than average anyway. I do everything on the car myself but admittedly I don't know anything about gearboxes. I can drop it out but don't know much about what's going on inside. Is there something simple I should check first or is it mashed because of lack of oil. Any info appreciated as always. Thanks.
Old Feb 3, 2014 | 12:52 PM
minder's Avatar
minder
common sense is called for there mate if you dipped the box and was dry of oil what do that tell you??
Old Feb 3, 2014 | 01:45 PM
haz87's Avatar
haz87
How did you dip it? Theres no dipstick?
Old Feb 3, 2014 | 07:02 PM
Fordmad!'s Avatar
Fordmad!
There's a filler plug mate undo that and see if there's any oil in it
Old Feb 3, 2014 | 07:04 PM
botters's Avatar
botters
competant bodger
the only dipstick on an xr3 is for the engine oil
Old Feb 3, 2014 | 08:01 PM
saul1988's Avatar
saul1988
5th always goes first when theres low or no oil
Old Feb 5, 2014 | 07:50 AM
Roberto_98's Avatar
Roberto_98
How ye lads
Yeah I know , I was just a bit puzzled why it was gone low because there's no evidence of a leak.
Old Feb 5, 2014 | 07:53 AM
Roberto_98's Avatar
Roberto_98
How ye lads
True but I made a dipstick relevant to what the manual says about how much oil goes in the box. There was no level on it so doesn't look too good really. New box I guess.
Old Feb 5, 2014 | 07:58 AM
Fordmad!'s Avatar
Fordmad!
The level in the box is basically fill it through the filler hole until it comes out then you know its full
Old Feb 5, 2014 | 07:59 AM
Roberto_98's Avatar
Roberto_98
How ye lads
I just made one via haynes and do it through the filler hole.
Old Feb 5, 2014 | 08:23 AM
haz87's Avatar
haz87
Fair enough. Anyway, yer if thats not registering owt then you've deffo run 5th dry. Drop the box slightly (remove cradle and support) then just pop off the end plate and have a look
Old Feb 5, 2014 | 08:25 AM
Fordmad!'s Avatar
Fordmad!
They are easy to take off. Personally if you need a new box id get a diesel box and puma linkage, makes a hell of a difference
Old Feb 5, 2014 | 01:29 PM
Roberto_98's Avatar
Roberto_98
How ye lads
Right lads thanks for the info. Time to get me hands dirty.
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
The Youth.
Sep 30, 2015 09:59 PM
deathrider666
Sep 28, 2015 06:12 PM
