EFI pressures please
Old Sep 24, 2013 | 11:25 AM
Wood5tock's Avatar
Wood5tock
Escort Mk4 Goodness
Default EFI pressures please
1990 1.6 CVH with EFI
Does anyone know the correct (standard) pressure that the fuel pump should produce and also the correct (standard) pressure that should be in the fuel rail?
Old Sep 24, 2013 | 12:07 PM
SBT83's Avatar
SBT83
Not Crazy, just Unwell
Not too sure myself on the pressure, but the fpr should sort it to the correct amount in the fuel rail.
Sorry can't help mate, someone will know
Old Sep 24, 2013 | 12:50 PM
Wood5tock's Avatar
Wood5tock
Escort Mk4 Goodness
Wanted to know what pressure the fuel rail should be as we think the FPR could be off as we found a SHONKY NUT on the adjuster
Old Sep 24, 2013 | 01:09 PM
SBT83's Avatar
SBT83
I've got a couple of pictures of zetec 2.0 and rs fpr if that's any good?? Doubt it but maybe you could make out from the numbers what it should be??
Old Sep 24, 2013 | 03:22 PM
Wood5tock's Avatar
Wood5tock
Escort Mk4 Goodness
You never know it may do
Old Sep 24, 2013 | 03:36 PM
SBT83's Avatar
SBT83
Emailed
Old Sep 24, 2013 | 03:57 PM
Wood5tock's Avatar
Wood5tock
Escort Mk4 Goodness
Thanks for the email mate but they are the sealed ones. The one we have is the earlier adjustable one arrowed.
We think this has been messed with so want to get it back to standard to prove if it's faulty or not
Old Sep 24, 2013 | 04:06 PM
SBT83's Avatar
SBT83
Yeah they used to wind them up back in the day. cant you do a few test runs to see how it runs while turning it down?
Old Sep 24, 2013 | 04:18 PM
Wood5tock's Avatar
Wood5tock
Escort Mk4 Goodness
Unfortunately not you see the EFI is SHONKED with Induction kits, bad exhausts, setting all over the shop, causing rough running, flat spots etc.
So we are gradually going back through the whole system gradually ticking the boxes getting it back, but this is the next thing. We have managed find the pressures should be 5.0 bar fuel pump and 2.5 bar at the fuel rail but wanted to get this confirmed.
Done so far
Standard Exhaust fitted
Standard Air Box fitted
Trottle body cleaned out
Idle valve cleaned out
pipes checked for leaks
Breather cleaned out
New plugs
Fuel pressure from pump = 4.0 bar
Fuel regulator... Next...
Old Sep 24, 2013 | 04:26 PM
SBT83's Avatar
SBT83
Your pretty much on top of it now then, might be worth a full self service if you havent already. obviously your half way there lol. FPR sorted, fuel filter, etc. Should come up sweet
Whats the milage like?
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
Dubs44
Sep 19, 2015 06:31 AM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
