tuning a fiesta zetec s
Old 01-09-2013, 09:50 AM
  #41
fordcozyjohn
fordcozyjohn's Avatar
ok thanks what one is in the fiesta has please
Old 01-09-2013, 10:32 AM
  #42
CrOwSoN15
Ben
CrOwSoN15's Avatar
If it has the inlet at the front of the engine, it's an SE, and they'll fit.
Old 01-09-2013, 05:36 PM
  #43
martysmartie
martysmartie's Avatar
Originally Posted by CrOwSoN15
Depends whether the Focus has a Zetec E engine or SE.
The answer is yes, as he said it's a 1600.
Martin
Old 01-09-2013, 05:50 PM
  #44
fordcozyjohn
thanks you you are gods
Old 01-09-2013, 08:15 PM
  #45
CrOwSoN15
Ben
CrOwSoN15's Avatar
Martin
So? Early Focus' were fitted with 1600 Zetec E's too.
Old 01-09-2013, 10:21 PM
  #46
martysmartie
Disagree, the engine was launched exclusively with this car, never have I known or heard of a 'silvertop' engine and these cars in the same sentence.
Martin
Old 02-09-2013, 08:06 AM
  #47
zetec-Sam
neeeeeeeeooowmmmm
zetec-Sam's Avatar
Nope, they were the Silvertop version of the Zetec SE, not the Zetec E as seen in the older Fiesta's etc.
Old 02-09-2013, 12:11 PM
  #48
CrOwSoN15
Ben
CrOwSoN15's Avatar
I stand corrected! I thought the early ones were fitted with the same 1600 as the late Escorts did.
Old 02-09-2013, 12:18 PM
  #49
SBT83
Not Crazy, just Unwell
SBT83's Avatar
I thought the only cars a zetec se sat in was the fiesta and puma. 1600 Zetec E's were in the escort and focus, focus having seen 3 versions of the zetec E??????
Marty shed some light
Old 02-09-2013, 12:19 PM
  #50
martysmartie
No, being the Focus was cutting edge, it couldn't be seen with that engine, hence the engine was launched with the car.
The ONLY Zetec-E engines fitted to these were the 1800 and 2L.
Martin
Old 02-09-2013, 12:25 PM
  #51
martysmartie
The ZS merely borrowed the Focus engine, that being a Sigma, or SE as you know it.
As I said above there was only 2 versions of the 'E' in the Focus, and two SE's.
The 1600 Zetec-E was fitted in the last of the Escorts and early Mondeos and is affectionately known as 'silvertop'.
Martin
Old 02-09-2013, 12:34 PM
  #52
SBT83
SBT83's Avatar
Got ya. I thought the focus had the silver top in early models, then the black top and later a revised blacktop hence the timing belt tensioners were different to the first blacktop?
Old 02-09-2013, 12:41 PM
  #53
martysmartie
You have what is known as phase 1 and phase 2 engines, the early ones had a metal cam cover with Zetec S engraved, which is what you are thinking of, while the latter had a black cam cover, either way it's still the same engine!
The 'silvertop' is what is references the old engine, i.e. the Zetec-E.
A 'black top', is used to refer to a 2L Zetec.
Martin
Old 02-09-2013, 01:02 PM
  #54
SBT83
SBT83's Avatar
Thanks for that matey : top:
Old 02-09-2013, 01:46 PM
  #55
It's Czech Mate
It's Czech Mate's Avatar
Martin
And the Mk3.5 Fiesta Si
Old 02-09-2013, 08:43 PM
  #56
zetec-Sam
neeeeeeeeooowmmmm
zetec-Sam's Avatar
Martin
Not necessarily, as the 2.0 came in silvertop and blacktop flavours, as did the Zetec SE's.
Old 04-09-2013, 12:18 PM
  #57
martysmartie
Usually when someone says a blacktop, they are referring to a 2L Zetec, phase 1 and 2 typically denote the Sigma.
Martin
Old 20-03-2014, 02:53 PM
  #58
doga-ot
doga-ot's Avatar
Originally Posted by asha1
I'd go Puma route to be honest, got a puma'd mk5 zs myself with cat back & k&n - granted its not the fastest thing on the road but it is bloody quick up to 4th ! I've found tuning is *quite* limited on the 1.7 though, can get FRP inlet, FRP cams, HD Big end bolts & FRP map, 4-2-1, should apparently get to around 150bhp - 160bhp (so i've read)
or if you can get hold of 1, an FRP engine.
Ash you will not get 160bhp with them mods you just said, someone I know has a zs with complete FRP conversion headwork,cams ete etc and he only just see's 146bhp and all that cost him 2k.... 2k fuck me Ł500 on a 1.6 S (sigma) engine would easily see 140-150bhp who in there right mind would spend Ł2000 on an engine for just 146bhp when for Ł1000 you could build a turbo engine with 250+bhp MADNESS!!!
Old 20-03-2014, 05:27 PM
  #59
CrOwSoN15
Ben
CrOwSoN15's Avatar
Ł2k using the right second hand bits would see 160+, bike bodies, LM4s, Miltek 4-1, a touch of head work and some rod bolts.
Old 20-03-2014, 06:21 PM
  #60
doga-ot
doga-ot's Avatar
What i was getting at why would you spend 2k on an engine for not much gain when you could build a bloody good engine from scratch for that with double,treble the power
Old 20-03-2014, 07:48 PM
  #61
CrOwSoN15
Ben
CrOwSoN15's Avatar
Different power delivery, personal preference I guess!
Would rather chuck the 2k at the chassis though.
TPM961
15-01-2018 10:50 AM
Andypandy260
23-09-2015 10:28 PM
focuspower
20-09-2015 03:51 AM
focuspower
19-09-2015 08:27 PM
dave1960
Ford Fiesta
16-09-2015 11:34 PM
Quick Reply: tuning a fiesta zetec s
