Focus Mk1 TDdi issues
Old Jul 31, 2013 | 11:13 PM
Slaney21's Avatar
Slaney21
Roflmaowtfbbqhax!
Default Focus Mk1 TDdi issues
Hello chaps
Putting this thread up to try and get some knowledge on an issue That came to light after a drive home today. Took a trip down the motorway home as a change of scenery and in doing so have discovered my ford focus 1.8TDdi has a very bad "vibrating" issue when accellerating over the 60mph mark and seems to be very noticeable at 70-80mph. Even when easing off the throttle when reaching said speeds it carries on for a few seconds until the speedometer reaches 55mph.
After checking around i have seen people mention things like driveshafts, engine/gearbox mounts, buckled alloys or warped discs. I have only had the car for 4 weeks and i would like to have it safe to drive and to keep it reliable as it's a good little motor. The only known problems i have with the car right now (before i discovered the above) is that there is a clunk sound from the gear lever when pulling away in first and sometimes second after a gearchange and a very annoying throttle problem which "sticks" in high gears?
Any assistance would be greatly appreciated.
Old Jul 31, 2013 | 11:31 PM
GVK.'s Avatar
GVK.
Is it felt through steering wheel? Could be a simple wheel balancing issue.
If felt through the seat could point to rear wheels out of balance/buckled wheel/out of shape rear tyre.
Clunk could be from engine mountings.
Usually if it's a driveshaft inner cv joint problem, you'd get a vibration under hard acceleration in lower gears as well as higher speeds.
Not experience a throttle sticking problem on Focus diesels before,not sure what to suggest there.
Old Aug 1, 2013 | 07:32 AM
Slaney21's Avatar
Slaney21
Roflmaowtfbbqhax!
Hello matey thanks for the reply
It appears mainly to be through the steering wheel and noticeable as the dash/body of the car vibrates along with it. I had a rear tyre changed recently so could be that the remainder all need ro be done as well? If i get time today i will see if a local garage is kind enough to have a look for me. Dont suppose suspension could play any part in it at all?
Old Aug 2, 2013 | 07:59 PM
cabriolet's Avatar
cabriolet
look at tyres and engine mounts [egg shaped tyre?]
Old Aug 2, 2013 | 08:33 PM
SBT83's Avatar
SBT83
Not Crazy, just Unwell
I've had this before! Wheels out of balance, and 1 was shaped flat as ifs at on flat tyre for yrs. a good balance should sort you out. Then see what happens with the clunking.
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Bailes1992
Sep 3, 2015 02:17 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
saph in dorset
Aug 14, 2015 10:10 AM
hazbaz1984
Ford Focus (All Models)
Jul 30, 2015 05:15 PM
