Zetec Turbo
Old Jul 15, 2013 | 07:35 PM
SBT83's Avatar
SBT83
Not Crazy, just Unwell
Default Zetec Turbo
Right, it's a series 3 zetec blacktop from a focus with a rover turbo inlet manifold. The problem is there is the "thermistor" in a dry pocket right where I've bolted the adapter plate. Obviously I've taken it out but where can I take a new feed from for this sensor. A cvh thermostat housing with sensor and do away with the probe?
Any help is appreciated
Old Jul 16, 2013 | 12:16 PM
SBT83's Avatar
SBT83
Any FRS boys encountered this when changing inlets??
Old Jul 16, 2013 | 12:56 PM
luke19790_3's Avatar
luke19790_3
Got a picture? Do you mean the knock sensor
Old Jul 16, 2013 | 02:13 PM
SBT83's Avatar
SBT83
Sorry haven't got a picture as of yet. It's a long brass probe that screws in just under the far right handside inlet port if you look at it dead on. It's a 15mm to undo and has 2 wires.
I need to get some pics! Description fail!
Old Jul 17, 2013 | 12:20 PM
SBT83's Avatar
SBT83
Pictures
Probe
And where my fingers pointing is where the dry pocket is. U can't see it because of the adapter plate but that's the location.
Old Jul 17, 2013 | 05:39 PM
SBT83's Avatar
SBT83
FRS boys??? Help needed.
Old Jul 17, 2013 | 05:46 PM
luke19790_3
Drill a hole in the plate or bin that crap and have the manifold welded so you don't need one. That's what I did
Old Jul 17, 2013 | 05:50 PM
SBT83's Avatar
SBT83
Yep think it might have to go that route. This what happens when you take shortcuts.
Cheers fella
Old Jul 17, 2013 | 06:56 PM
crazycage's Avatar
crazycage
im sure that's just a oil temp sensor
Old Jul 17, 2013 | 07:28 PM
studabear's Avatar
studabear
Cylinder head temp sensor that is.
What car is the zetec in, and what management is fitted? as if its in a dry pocket you can prob just do away with it.
Old Jul 17, 2013 | 08:02 PM
SBT83's Avatar
SBT83
I thought it was! Just needed confirmation. It's not in a car at min but I'm gonna run megasquirt I think.
Cheers lads
Old Jul 17, 2013 | 08:18 PM
SBT83's Avatar
SBT83
Lets just say I ran ofab could use the cvh thermostat instead? But saying that I'd need an inline temp sensor to run MS anyway
Old Jul 17, 2013 | 08:33 PM
rsmark86's Avatar
rsmark86
yep theres a guy on ebay i spoke to selling cvh to zetec turbo head adpator plates for the thermostat to bolt to you head and means you can keep the cvh top water hose
if your running the ofab ecu you will need to change to the cvh housing or run your fan on a on/off bodge switch
the zetec fan is controlled by the ecu from what i can work out so the ofab wont support it and if you putting it in a cvh car then the standard car loom/ fan loom wires up and powers the fan, much better way of doing it than running the fan of a switch in the car
Old Jul 17, 2013 | 08:55 PM
rsmark86's Avatar
rsmark86
http://www.ebay.co.uk/itm/zetec-bang...6#ht_95wt_1172
link, he told me it comes with the counter sunk bolts so no drilling or tapping
Old Jul 17, 2013 | 09:03 PM
crazycage's Avatar
crazycage
mine used to leak oil from there , I put a grub screw in it to stop it .
Old Jul 18, 2013 | 09:29 AM
SBT83's Avatar
SBT83
Cheers guys! Crazycage those manifolds look the nuts! I've just bought gadgets area six, he mentioned he was getting one off you
robnock
21
May 13, 2019 05:29 PM
robnock
Aug 22, 2015 10:51 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
