Fuel Swirl Pot Setup Question
Old May 13, 2013 | 11:09 AM
Straight_4_N/a's Avatar
Straight_4_N/a
Default Fuel Swirl Pot Setup Question
Right ive got what i beleive is all the needed for my swirl pot setup and i beleive i know how to plum it in but can so correct me if im right or wrong please thank you.
Parts
Fuel swirl pot
Fuel filter
fuel pump
fuel line
hose clamps
How to fit.
Swirl pot
top hose is feed for tank return pipe
hose just below that is the for engine return
hose just below that is swirl pot feed from tank
and the bottom one is for second fuel pump feed/engine
which way to setup.
Swirl pot the fuel filter then fuel pump then engine.
Wiring.
Just wire new fuel pumps live and ground into exsiting fuel pump wires.
Does this all sound about right?
Thanks
Old May 13, 2013 | 11:26 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
I'm just about to do mine as my after market tank surges like fuck lol
I'm going to use the set up on the car now 044 pump then filter to run into the boot and feed my 1.5L surge tank which will then feed a second 044 which will feed the rail got a 4 port -8 tank from eBay for 40 quid
I'm going to wire my second pump in on its own relay with a 12v battery supply just like the one that's on the car now but the relay will share the earth and ecu trigger wire with the first pumps relay! The pump its self will share the first pumps earth at the rear of the car
Old May 13, 2013 | 11:38 AM
Straight_4_N/a
i didnt have any problems with my std tank last time it was on the track but next time it goes out the car will have loads more grip and an extra 50bhp ish so im fitting one just incase lol. Im using the stock fiesta pump to feed the pot which should be more than enough and im using a facet sliver comp pump 5psi upto 200bhp to feed the engine which should be more than enough as im only look at 170bhp ish once i finsh/start the engine.
Old May 13, 2013 | 11:43 AM
ajamesc's Avatar
ajamesc
I had my standard cosworth tank on the car for about 4 years with 500bhp and it never surged once but got an after market one had it aero quipped and painted fitted it to the car and the swirl pot in it is shit!
I can't be arsed to get the standard one modded and painted so I'm taking the surge tank route
Old May 13, 2013 | 05:05 PM
Straight_4_N/a
Right now im confused.com
Anit a fuel swirl pot and a surge tank the same thing?
Old May 13, 2013 | 05:07 PM
ajamesc's Avatar
ajamesc
I think there the same mate
Old May 13, 2013 | 05:25 PM
DixieTheKid's Avatar
DixieTheKid
Pick-up P100 Power!
you dont need 2 x 044 do you? Cant you use a std and a 044?
Old May 13, 2013 | 05:28 PM
ajamesc's Avatar
ajamesc
If your talking to me bud my car already has an 044 on it so I may as well leave that wear it is and let the surge tank feed another 044 but no I don't really need 2 as one is good for 600bhp
Old May 13, 2013 | 05:37 PM
DixieTheKid
Pick-up P100 Power!
Im just going off of what ive been told but......., i have have a P100 and im using that standard tank (no internal swirl) and was told to get a std pump, an 044 and a swirl pot (1L / 1.5L). Ill be running 450 ish bhp.
I assumed that the std pump would feed the swirl and the 044 the reg and injector's. Could off miss understood, hence the interest in the tread.
Old May 13, 2013 | 05:41 PM
JOHNDQ's Avatar
JOHNDQ
True you only need a low pressure pump really as its only job is to keep the swirl pot topped up which is only 2 litres at most
Old May 13, 2013 | 05:44 PM
ajamesc's Avatar
ajamesc
Only reason I'm using two 044's is because my hole fuel system is aero quipped and looks nice and neat so I'll just re plumb it with line from the filter going into the boot to the surge tank then that will feed the second 044 as I need an 044 to feed the rail will join the line that feeds the rail that's already on the car
Old May 13, 2013 | 06:06 PM
DixieTheKid
Pick-up P100 Power!
Thanks bud Thought i had to spend more dosh
Old May 14, 2013 | 07:19 PM
The Underdog's Avatar
The Underdog
you cant fix stupid
not sure about your engine luke but mine pumps up to about 60psi at the rail from what ive read. if your pumping from swirl pot to rail at 5 psi will it run ok?
im no expert though as ive never done this but just thinking
Old May 14, 2013 | 07:41 PM
fraser9764's Avatar
fraser9764
I guess you are running carbs then?
Old May 14, 2013 | 08:11 PM
Straight_4_N/a
fuck fuck fuck FUCK!!!
Am i thick or what.
i needed 5 bar not psi
Anyone reconmend me a good pump before i piss £100 any again
Old May 14, 2013 | 08:13 PM
Straight_4_N/a
No by the looks of it ive cocked up and mixed up bar and psi and thinking 5bar would be enough i ordered a 5psi pump without thinking.
Old May 14, 2013 | 08:15 PM
Straight_4_N/a
it would only just get to the fuel rail let alone be enough to feed the engine
Old May 14, 2013 | 08:21 PM
Straight_4_N/a
well ive found a replacement pump.
Syntec pump 8.5 bar should be more than enough or is it over kill?
its going to be run a 1.7 Zetec-SE VCT Engine running 125bhp but will be at 170bhp+ at the end of the year
Old Jun 22, 2013 | 05:01 PM
mikeymikeyp's Avatar
mikeymikeyp
im going to be fitting a inside tank to a fez turbo of a mates and i was just going to take the return to the tank and the feed from the tank to the swirl pot and from the pot to the fuel rail ,The tanks got a fez turbo pump in it like
does that sound about right
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
15
Oct 7, 2015 03:43 PM
Marino
Sep 12, 2015 11:10 AM
Rizlablue
Sep 6, 2015 10:54 AM
