cosworth tps
Old Apr 30, 2013 | 06:06 PM
s2erst's Avatar
s2erst
Default cosworth tps
Hi can anyone help tonight i checked my tps on my cossie to see if it was working right and found that on close throttle its 4.9v but when i go to open throttle it doesnt change what so ever mine is 2wd so im told it should go to 0 so does this mean my tps is no good cheers for any help
Old Apr 30, 2013 | 07:25 PM
daz1968's Avatar
daz1968
Sound like it isn't working at all, which terminals in plug are you checking, think 17 and 11 are the ones to check, terminal 30 is control voltage which would be 4.9 volts constant, you can also do a resistance check between 11 and 17 as it has a open circuit at closed throttle then a smooth resistance increase from just open to fully open throttle.
Old Apr 30, 2013 | 07:54 PM
creator's Avatar
creator
Think its pins 17 and 32 on the exu mate
Old Apr 30, 2013 | 07:57 PM
s2erst's Avatar
s2erst
I done it straight from the plug itself
Old May 1, 2013 | 07:43 AM
onslack's Avatar
onslack
https://passionford.com/forum/ford-s...s-setting.html
Old May 1, 2013 | 08:08 AM
s2erst's Avatar
s2erst
Yeah i did see that bud. Am i ok to check voltage straight from plug rather then ecu as thats what i done im getting the 4.9 volts on closed throttle but not going down when opening it so to me its says my tps is no good
Old May 1, 2013 | 08:51 AM
onslack's Avatar
onslack
umm.. im not 100% sure buddy, have you tried getting a reading from the ecu pins themselves?
Old May 1, 2013 | 08:55 AM
s2erst's Avatar
s2erst
No bud as thought it would be better to go straight to plug itself. if im getting the 4.9volt on closed throttle then i must be testing it right. I just need someone to confirm im ok to check voltage from plug rather then ecu
Old May 1, 2013 | 09:18 AM
XR4iSilver's Avatar
XR4iSilver
Quickest way if you can put on a collins monitor or pectel see what the ecu sees
Old May 1, 2013 | 12:40 PM
martysmartie's Avatar
martysmartie
No LOL, by checking at the plug you are measuring the input, that won't vary as the potentiometer (TPS) is not connected. You need to measure at the ECU.
Also PF01 (2WD) should be open circuit at idle.
Martin
Old May 1, 2013 | 12:51 PM
s2erst's Avatar
s2erst
Martin
Ok thank you ill check it at the ecu tonight
Old May 1, 2013 | 05:28 PM
s2erst's Avatar
s2erst
Martin
By the way the tps is still connected I just pulled the cover off back of plug so I could get to wires. checked it tonight and is 4.9 on closed throttle an on full throttle goes down to 0.5 so must be working ok
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
