S1 EFI ofab conversion wont start!!!!!!!
Old Jan 21, 2013 | 09:47 AM
fordRSowner's Avatar
fordRSowner
Default S1 EFI ofab conversion wont start!!!!!!!
Hi Chaps
Im having a little difficulty with my efi conversion on my s1. i have fully installed the ofab loom and ecu with the necessary relays for fuel injection and fuel pump etc... i have spark and plenty of fuel but i can only seem to get the car to fire with a squirt of solvent down the intake???? then it runs reasonably well with a bit of missfire. ive checked pretty much all the sensors on the engine. All this wiring and ecu was removed from my fiesta turbo which was all running spot on!!!! Ive read a few similar storys on here regarding these issues but the threads seem end without a conclusion??? lol This is realy driving me up the wall now, any help and advise would be very much appreciated guys?????
CheeRS
Old Jan 21, 2013 | 09:50 AM
Stolton's Avatar
Stolton
Have you checked all the earths mate? i had the same problem on my series 2 when i EFI converted it and it was a earth. Sent me crazy for ages so i know how you feel. You using a FRST block with CPS built in the block or a 36-1 trigger wheel?
Old Jan 21, 2013 | 11:07 AM
fordRSowner
Hi mate thanks 4 the quick reply, i thought it could be a dodgy earth but im pretty sure they ok. Where abouts did u get a ground fault if u dont mind me asking bud?. i am using standard frst flywheel and pickup.
Old Jan 21, 2013 | 11:25 AM
Stolton's Avatar
Stolton
The problem i had with mine was i couldnt get it to spark and it eneded up being the small brown earth wire that runs along with the amal valve wiring. Most people hate wiring i know i sure do lol best thing to do is go over all the wiring again and exactly what you have done & double check i had to do that a few times.
My mates just built a fiesta rs turbo and he is having the same problem as you with having a spark and having fuel up to the injectors but only fires on like brake cleaner or easy start up the crossover pipe.
Old Jan 21, 2013 | 11:27 AM
Stolton's Avatar
Stolton
There is alot of members on here that will know exactly your problem is but untill they read your thread best bet is to do some research for similar problems mate
Old Jan 21, 2013 | 11:53 AM
fordRSowner
Thanks bud I've checked that anal valve earth, that's connected to the body as I should be. Yes I read about the chap with the same problem having to use brake cleaner to start. It's certainly a strange one I've done a few efi zetec conversions in mk4 escorts with no issues what so ever so I'm stumped on this one lol.
Old Jan 21, 2013 | 12:24 PM
gup's Avatar
gup
What starter motor are you using as when I converted my van to a turbo I used the original diesal starter motor and it took ages to start used to back fire then start
Took me ages to find out
But the diesal starter works on a pulse and this was interfering with the cps signal
I fitted a old fiesta starter I had and it was fine
Old Jan 21, 2013 | 01:17 PM
fordRSowner
Hi I'm using a starter from an escort rst which seems to be working well. My cps tested spot on with a meter on crankin so think thats all good. The only sensor i havent changed is the air charge one on the inlet manifold (Rightside) but will that realy stop it starting? Poxy thing!!!!!! lol
Old Jan 21, 2013 | 03:17 PM
gup's Avatar
gup
Have you got your speed sensor plugged in as my van wouldn't start start without it plugged in I'm running ofac
Old Jan 21, 2013 | 03:25 PM
fordRSowner
No speed sensor not connected mate i didnt think it needed 2 be? Maybe i should plug that it then but not sure if ive got the wiring from the gearbox im sure ive got one somewhere from my fiesta. Thanks 4 your help by the way gup
Old Feb 1, 2013 | 01:54 PM
fordRSowner
Still no joy with engine starting problem!!!!! My injectors are not pulsing and cranking??? They pulse when the fuel pump primes though. I cant think where else to look anymore lol. One thing I have noticed is that I have 12 volts to both injector wires when ignition on im sure this isn't right. Anymore suggestions guys?
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
xrmalin
Sep 13, 2015 06:52 PM
EoinXR3
Sep 7, 2015 05:44 AM
kevin36
Sep 2, 2015 06:24 PM
Dahl88
Aug 22, 2015 08:16 PM
