creaking/ scratching noise from front wheel
Old Jan 19, 2013 | 03:26 PM
Daniel-1986's Avatar
Daniel-1986
Default creaking/ scratching noise from front wheel
i got a noise coming from my front wheel, i changed the pads as i thought it mite be crap stuck in them but the noise is still there
heres a vid of the noise
Old Jan 19, 2013 | 04:04 PM
Fordmad!'s Avatar
Fordmad!
Is it definatly that wheel? Jack the wheel up and turn it by hand. Also wiggle it side to side and see if the bearing is okay!
Old Jan 19, 2013 | 04:08 PM
Daniel-1986
seems to be that wheels yeah, ill hav a go at wiggling the wheel wen the weathers better
Old Jan 19, 2013 | 05:03 PM
minder's Avatar
minder
hi mate
i'll tell you exactly what that noise is its a build up of dirt and grit that's built up between
the drive shaft and the hub take the wheel off get a small flat head screw driver and some one to turn the disc while you scrape the screwdriver in the gap between the hub and shaft and after a few spins squirt some white grease into it and the noise should go
repeat this every 2/3 months and itll be fine i know its that as it happened to my RS
Old Jan 19, 2013 | 05:17 PM
Daniel-1986
cheers, ill give that a go
Old Feb 3, 2013 | 10:00 PM
Daniel-1986
cleared out the hub and driveshaft and put white grease in there and there wheel bearing seems ok, by the off chance could a slightly warped disc moving the piston or pads on the hub cause the noise, as one my discs is possibly warped slightly as I have a bit of brake pedal judder (ABS isn't fitted to my focus)
Old May 12, 2013 | 07:44 PM
Daniel-1986
Still got.this noise, think I may hav worked out wat it is as it didn't show up on the mot, I think it may be coming from the intermediate bearing where the driveshaft is bolted to the bottom of the car next to the inner cv joint, is the bearing inside the driveshaft itself or separate as gonna change either of them when I hav the clutch done soon
Old May 12, 2013 | 08:01 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
If you suspect the bearing the noise is probily the disc hitting the backing plate when you have the weight on the wheel, its a pressed in bearing
Old May 12, 2013 | 08:08 PM
Daniel-1986
Got no backing plate behind my discs plus its had brand new discs and pads to see if it's goes which means it can only be a bearing
Old May 12, 2013 | 09:15 PM
gingerturbo
Oh fair dos in that case it probily is a bearing,do you use brake cleaner at all
Old May 12, 2013 | 09:19 PM
Daniel-1986
No aint got non that, I asked about the noise at a local garage and he sed it cud be the bearing where driveshaft is supported to the bottom of the body as they've changed loads, it's a mk1 focus as didn't say in the op, noise has been there since just after I bought the car
Old May 13, 2013 | 05:53 AM
gingerturbo
Yeh just general wear and tear on the bearings
malkiemac3579
Jul 14, 2017 12:10 PM
Chas
Sep 21, 2015 08:57 PM
C2 MAK
Aug 20, 2015 09:46 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 07:06 AM
muz
Aug 1, 2015 06:48 AM
