st170 xenon headlamp conversion
Old Jan 9, 2013 | 11:15 AM
CrisCronin's Avatar
CrisCronin
Default st170 xenon headlamp conversion
hi guys,
looking into swapping over my standard mk1.5 lamps with the st170 xenons. now i understand that you need washers ect to pass the MOT but is it 'easy' to do? do i need extra wiring; if so what?
any help is much appreciated
Thanks!
Old Jan 9, 2013 | 02:27 PM
Ali_B's Avatar
Ali_B
you dont need washers if xenons wernt fitted as standard. my RS passes with them every year.
for the rs i had to change some internal wiring, but unsure if you will need to do the same, i can dig the diagram out if you need it.
all you need is the headlights, bulbs, ballasts, and ignitors.
Old Jan 9, 2013 | 10:16 PM
CrisCronin's Avatar
CrisCronin
Oh ok that's great then. Got a friend anyway
And if you could that would be very helpful! Haven't been able to find much info on the Internet so far
Old Jan 10, 2013 | 02:39 AM
Ali_B's Avatar
Ali_B
try and follow this diagram
Old Jan 10, 2013 | 02:41 AM
Ali_B's Avatar
Ali_B
does the 1.5 have indicators in the headlights? or down on the bumper?
because the FRS's are down on the bumper you might have issues.
Old Jan 14, 2013 | 06:53 PM
CrisCronin's Avatar
CrisCronin
sorry for the late reply, but the MK1.5 does have the indicator in the headlamp.
will the wiring differ a lot or?
Old Jan 16, 2013 | 06:21 AM
Ali_B's Avatar
Ali_B
i honestly dont know if the wiring will differ, it might be worth getting an auto electrician to have a look, or you could always follow the diagram and hope,
the FRS has the same high and low beam as a 1.5 but with indicators in the bumpers. there was a german website that tolk you how to do the hole thing, including washer jets and auto levels on the suspension, bt i cant find it any more... sorry i couldnt help more
Old Jan 16, 2013 | 12:10 PM
CrisCronin's Avatar
CrisCronin
Yea I he thought of that which what I might have to do as a last resort!
I've found that website, ( www.Foka24.de/Focus/Xenon.html )but Google Translator isn't the best
I'm going to buy a pair anyway and ill make some decent instructions and update.
Thanks for your halp mate
Old Jan 10, 2021 | 05:03 PM
Ber23's Avatar
Ber23
Hi friends, I have these st170 xenon headlights to install on my mk1.5, but I don't know what I should modify, (it turns on position, long and blinkers, but the xenon does not) the headlights work. can you help me please
Old Mar 1, 2022 | 03:14 PM
Steve, nottingham's Avatar
Steve, nottingham
Default St170 wiring
Hi Cris Cronin
Did you ever manage to get those lights wired up?
If so could you please let me know which wires needed changing, splicing or bridging.
im struggling to find the correct information.
many thanks in advance.
Steve, nottingham.
batrst
Jul 12, 2016 10:05 PM
RSRick3290
Ford Focus ST
Mar 20, 2015 09:53 PM
Takeshi
Ford Focus ST
Sep 24, 2012 09:04 PM
superhans
Ford Focus RS
May 2, 2009 09:08 AM
