removing air bag to fit after market wheel
pull the negative lead of the battery and wait 20 mins for the air bag to de activate,then remove the air bag fuse from the fuse box, there should be a couple of screws on the back of the steering wheel holding air bag module on un screw these ( u may have to take the steering colum shrouds of to get at these screws) and lift of the unit and disconnect the wiring going to the bag , remove unit and store away safely,
dont do this job with a cig hanging out of your mouth and keep ur mobile well away, when carrying the unit keep it at arms length and with the exploding bit facing away from u (common sence really).
when u have done this u just unbolt the wheel boss nut and the rest is self explanatory, but remember, u may have to fit a new horn switch, and of course the air bag light on the dash board wil be lit constantly but u can rip out the bulb
ok mate
ok mate
JoeyBoyden
04-01-2024 03:36 PM
Jack and the Beanstalk
15-08-2015 05:27 PM
track.focus'd
12-08-2015 06:53 PM
