Amal valve problems!!!!!!!!!!!!!!!!!!!!!!!! FFS!!!!!!!!!!!!!
Old Mar 9, 2005 | 03:27 PM
palmer3914's Avatar
palmer3914
Default Amal valve problems!!!!!!!!!!!!!!!!!!!!!!!! FFS!!!!!!!!!!!!!
Put smits amal valve on mine and it was smoother boosting and only 18psi, while mine is nothing nothing nothing nothing!!!! 24psi!!!!! and at 20-21 it cuts and then carrys on ........ and when dis-connected my amal valve and then run the car - NO DIFFERENCE same boost same lag!!! would this mean my amal valve is FCUKED!!!! or could it need to be re-jetted as mine would only seem to have 1 jet and thats it...... or should i just get a bleed valve ???? ideas's / help / opinion's / abuse all wanted!!!!
Old Mar 9, 2005 | 04:48 PM
Dave Henshall's Avatar
Dave Henshall
on what car, a sierra or escort? does it click when it powered up?
Old Mar 9, 2005 | 10:54 PM
palmer3914's Avatar
palmer3914
sierra 2wd....... and as for clicking.... well im not sure what your talking about then???
Old Mar 9, 2005 | 11:24 PM
GrimmeRS2K's Avatar
GrimmeRS2K
when you turn your ingntion on 2 clicks it should click if its working fine
Old Mar 10, 2005 | 07:48 AM
Dave Henshall
and while the ignition is on 'click 2', if you pull the wires off the alam valve, it should click as u do it, and reconnect it.
Old Mar 10, 2005 | 08:44 AM
palmer3914's Avatar
palmer3914
ahhhhhhh i see.... i will now go and test it"!!!!!!!
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
routemaster
Sep 7, 2015 05:27 PM
cossirob
Sep 3, 2015 09:17 PM
