Fuel pressure for 45 DCOE's??
Old Aug 27, 2012 | 04:05 PM
scott-78's Avatar
scott-78
Default Fuel pressure for 45 DCOE's??
I have a 2.0 Zetec silvertop in my car with 45 DCOE carbs... what fuel pressure should I feed them with?
any help with this would be much appreciated...
Old Aug 27, 2012 | 04:30 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
normally between 4 and 6 psi
Old Aug 27, 2012 | 08:31 PM
scott-78's Avatar
scott-78
thanks for the reply. On Ebay there are some Facet fuel pumps rated at 4-6psi but obviously that is maximum.
The next one up from that is a 7-10psi pump. Im guessing it would be better to get the higher one and a regulator to drop it to 6psi for a more constant flow?
Old Aug 27, 2012 | 11:32 PM
macrs2k's Avatar
macrs2k
45's only need around 3 psi mate...Get a facet pump and filter king regulator and set the pressure with that
Old Aug 27, 2012 | 11:41 PM
allaboutfords's Avatar
allaboutfords
Smile
Hi yes there right i had loads of probs useing the wrong pump and reg on a ZVH with twin 40s. I bought a red top pump and yes a filter king pressure reg with the filter in and all probs sorted. I had mine set quite low then as I had it on 2 psi. Try getting them from Fuel system Enterprises (http://www.glencoeltd.co.uk/) Tell them your trade and get delivered to a local garage and it will be a lot cheaper.
Old Aug 28, 2012 | 06:40 AM
scott-78's Avatar
scott-78
thanks.. that looks like a good company and have some other stuff that I need too.
I am in the trade so I wont need to fib luckily
Old Aug 28, 2012 | 08:30 AM
RS2000CUSTOM's Avatar
RS2000CUSTOM
Max 3.5 psi anymore will damage the internal floats
Old Aug 28, 2012 | 12:24 PM
0150carmac's Avatar
0150carmac
i used a faclet elec pump and regulator set to regulate at 3 psi on a kit car with a dohc ford engine on 45,s worked a treat like
Old Aug 28, 2012 | 05:35 PM
scott-78's Avatar
scott-78
thanks again for the help guys. 3 psi it is then.
I guess without advice that doesnt sound a lot, and with guesswork I'd have gone in too heavy handed. Time to source a pump now and get under the car again!
Old Aug 28, 2012 | 05:57 PM
cossyking's Avatar
cossyking
you want a facet red top pump mate not very expensive new thats what i got on my mexico and runs spot on
Old Aug 28, 2012 | 08:46 PM
scott-78's Avatar
scott-78
Sounds like a plan! I like the look of those. That'll be this months purchase then .... or as I like to think of it, an investment
timsrs
Nov 13, 2018 11:48 AM
A.t.p
Oct 23, 2015 07:54 PM
SMILER258
Sep 28, 2015 09:04 AM
