Saph 4x4 running problems
Old Jul 17, 2012 | 07:52 PM
Mikey Buchan's Avatar
Mikey Buchan
Default Saph 4x4 running problems
Hey guys, am after some hints and tips here from you peeps.
I've got a 1992 j reg saph 4x4 ebony black. i ahd been getting problems with an after market immobiliser which was wired into cut the starter. Removed it and had rewired it all and car turns over perfect. There was a alarm system fitted (cut)into the orignal alarm so I also removed that too and rejoined the 2 wires that was cut.
The problem I now have is that I get power up to my Group A coil but nothing out of it, checked my ecu loom for power and hey presto nothing either, fuel pump works cos its been rewired at some point but no spark.
Anyone able to help me out here? Only had her back on the road for 2 weeks too
CheeRS in advance
Old Jul 17, 2012 | 08:55 PM
martysmartie's Avatar
martysmartie
I will give you a hint "Checked my ECU loom, and hey presto, nothing either" you have kind of answered your own question, hence you have no spark
You need to trace this back and see why the ECU has no power.
Martin
Old Jul 18, 2012 | 06:53 PM
Mikey Buchan
Martin
Yeah a know that mate was looking for help on where to go next or a how to for by passing the standard immobiliser on it too
Old Jul 18, 2012 | 07:44 PM
rog's Avatar
rog
Sent you a PM, before we discuss immobilisers I'd check your ecu fuse and see if it's blow or keeps blowing after you change it.
Old Jul 18, 2012 | 08:38 PM
Mikey Buchan
sent one back to you Rog
Old Jul 19, 2012 | 02:06 AM
kevmc76's Avatar
kevmc76
scrap it and sell me your engine?
Old Jul 19, 2012 | 12:08 PM
martysmartie
As I say you need to trace the wiring back to the ECU relay etc, I don't think the standard immoby cuts the ECU power, I thought it cut ignition?
Martin
Old Jul 19, 2012 | 04:27 PM
Mikey Buchan
Now now Kev if it had been jap I would of
Old Jul 19, 2012 | 04:56 PM
rog's Avatar
rog
I'm in Peterhead now picking up a gearbox with Morgan, if
u want me to swing in by and take a look give him a shout.
Old Jul 19, 2012 | 10:28 PM
Mikey Buchan
dam it, am not back home until the morn bud, drop me a pm with your number etc and i'll give you a shout mate
Old Jul 19, 2012 | 11:05 PM
4x4kiwi's Avatar
4x4kiwi
A bit confused from your first post what has been removed but thought I would mention that I have found that if you remove the factory alarm module the car will not start. Although I could not find it on the wiring diagram there is obviously an ignition feed going through a normally closed relay inside the module. David
Old Jul 20, 2012 | 01:43 AM
kevmc76's Avatar
kevmc76
its not my fault i have a jap fetish
Old Jul 20, 2012 | 02:56 PM
Mikey Buchan
Rog send me a pm with ur number
Old Jul 20, 2012 | 07:57 PM
Mikey Buchan
Got it running with what james from Motorsport developments said to do but no boost now, no power to the amal valve
Old Jul 20, 2012 | 09:58 PM
rog's Avatar
rog
Bypassed the immobiliser?
Amal valve has a permanent live (black & red wire) and switched negative from the ecu.
Old Jul 20, 2012 | 10:34 PM
Mikey Buchan
put a key live onto the ecu power with a 30amp fuse and it started no problem, took it out and theres not the same boost as before, check the wires going to the amal valve and had no live power
Old Jul 21, 2012 | 08:13 AM
NEIL A's Avatar
NEIL A
Good to see you got it running Mikey
There is alot of helpful people on here.
Old Jul 21, 2012 | 09:55 AM
martysmartie
Do you have power at the amal valve, you need to check this first?
It's powered via the fuel pump relay, so the fact it's running suggests this to be working, unless you have altered your pump wiring?
In addition to what I said above, if you get someone to switch the ignition on whilst you touch it you should be able to hear/feel it 'click'?
Martin
Old Jul 21, 2012 | 02:56 PM
Mikey Buchan
Fuel pump has been altered Martin, no power or no clicking etc to the Amal valve.
There is alot of helpful people here Neil
Old Jul 21, 2012 | 02:59 PM
martysmartie
Well thats why then, as I say power is supplied to the Amal via the fuel pump relay, so I would start by checking this.
Martin
Old Jul 21, 2012 | 03:03 PM
Mikey Buchan
Amal valve has worked the way it's been wired for months :S it's only stopped ever since I run a key live to the Ecu
jason_nike
Aug 18, 2019 10:53 AM
c20tbo
Aug 17, 2015 10:19 PM
Zoggon
Aug 10, 2015 10:39 AM
yawiejon
15
Aug 9, 2015 06:36 PM
ray barker
Aug 7, 2015 09:00 AM
