Goodridge brake hoses fitting problem (pic)
Old Jul 15, 2012 | 10:22 AM
Cossy Mike's Avatar
Cossy Mike
Default Goodridge brake hoses fitting problem (pic)
I've gone to flare and form my brakes pipes on my Cosworth and the Goodridge hoses supplied done seem to fit
Am I doing something wrong here?
There not enough threads left for the Brake union. The nuts seem a bit thick, should they not be a shallow type?
Thanks!
Old Jul 16, 2012 | 09:14 PM
kaighn80's Avatar
kaighn80
yes thats not going to work as you wont have enough sticking through to get a compression fitting onto, are the ends both the same, otherwise your going to have to speak to goodridge and see what they recommend
Old Jul 17, 2012 | 04:34 AM
Cossy Mike's Avatar
Cossy Mike
Washers too thick and the nut it's the problem with the longer hose that goes between the rear arm and the body.
I've ordered up some m10 stainless half nuts and I'll use thinner washers.
If it works I'll be complaining to Goodridge
JoeyBoyden
Jan 4, 2024 02:36 PM
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
track.focus'd
Aug 12, 2015 05:53 PM
Red_bull
Aug 9, 2015 08:34 AM
