MK4 RS MFI Turbo Wont Fire
Old 17-06-2012 | 02:31 PM
djchurch2001's Avatar
djchurch2001
Default MK4 RS MFI Turbo Wont Fire
Havin a real issue getting my turbo started since replacing the following parts.
Plugs
HT Leads
Coil
Valves
Cam
Stem Sills
Injectors
Distributor cap
When i put the car back together the car did fire and was running but sounded rough so i swtiched it off and now i cant get it to fire. She will turn over but not hint of firing. I have checked all plugs are sparking and they are and all plugs seem wet with fuel. The car has been sat over winter so from what i have read on hear i have also replced the fuel.
Any help on this matter would be appreciated
Old 18-06-2012 | 07:15 AM
RSargie's Avatar
RSargie
Have you tried disconnecting the cold start valve, also check its not leaking. This can cause over fuelling and wetting the plugs. Also check the fuse for the Bosch Ecu ( heated seat fuse) make sure this is good
Matt Baxter
16-09-2015 09:30 PM
EoinXR3
07-09-2015 06:44 AM
A.t.p
15-08-2015 12:37 PM
marky_g
15-08-2015 11:43 AM
Sjieter
05-08-2015 10:47 PM
Quick Reply: MK4 RS MFI Turbo Wont Fire
