st170
Old Jun 16, 2012 | 06:36 PM
eva de silva's Avatar
eva de silva
Default st170
my inlet manifold sounds like its ticking is this normal? it also rattles slightly when reving gently . ive listened up close under bonnet and it sounds possibly like the rattle is inside the inlet manifold? could this be the case that its knackered or could there be something else around that area that is common to rattling?
Old Jun 16, 2012 | 07:15 PM
Cq182's Avatar
Cq182
My oil pressure gauge rattles slightly
Under load, worth checking I guess
Old Jun 17, 2012 | 05:06 PM
eva de silva
Cheers will check that! is there anyone on here had problems with the inlet manifold or can confirm if theres makes the ticking noise?
Old Jun 18, 2012 | 12:54 PM
Sp3no's Avatar
Sp3no
The injectors tick, BUT if there is a noise from around the inlet that makes a ticking it is most likely your IMRC, is it loud from inside the cabin? If this goes it should throw a fault code though.
The ST170 engine can be quite tappy/ticky due to injectors and solid lifters
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
Andypandy260
Sep 23, 2015 10:28 PM
pie-face
Sep 15, 2015 10:43 AM
