mechanic baffled
Old May 23, 2012 | 06:51 PM
clyde 1800's Avatar
clyde 1800
Default mechanic baffled
pinto injection engine missing when you rev it
car idles up and down a little and then if you rev the car up it dies out as if you reached in and turned the key off
but then returns to idle
we put the timing light on it and it is 100% on the timing cam and ignition timing
and when the the timing light is in it isnt losing spark at all
has to be a wiring problem i think maybe someone will know?
all earths look good
please help
Old May 23, 2012 | 06:53 PM
E980VTJ's Avatar
E980VTJ
sounds like fuel
Old May 23, 2012 | 06:58 PM
boy-racer-1's Avatar
boy-racer-1
first thing i would have said is ignition timing, but being thats fine maybe its the injectors or fuel regulator?
Old May 23, 2012 | 07:05 PM
dojj's Avatar
dojj
Resident Wrestling Legend
you don't have an air flow meter to measure the air going into the engine
and if you have fitted one since the picture was taken, see that when you move the flap inside that it's moving nice and smoothly, otherwise it's the sticky track inside that's causing it to mis
Old May 23, 2012 | 07:07 PM
clyde 1800's Avatar
clyde 1800
i put a fuel pressure regulator on it and tweaked it ever so slightly bit at a time until it wouldnt go at all each way
the fuel rail may be a possibility thank you thank you for all your comments all help appreciated
how do you suggest i fix this? could i take put anything in the fuel to flush out the injectors or injector rail if they are maybe clogged with dirt or should i remove them and replace or can they be cleaned?
and how do you suggest i do this?
Old May 23, 2012 | 07:10 PM
clyde 1800's Avatar
clyde 1800
yea thats the engine out of the car
i will put a picture up tomorrow of the complete set up in the car how could i clean the airflow?
there is one on it and is free to move inside with your fingers
Old May 23, 2012 | 07:13 PM
dojj's Avatar
dojj
it's mainly afm on the blink, make sure the wiring is sorted
otherwise check the throttle position sensor as they have been known to go wrong too
you need the ones with the gold wires from memory but they seem to be all the same across the for range fomr those years
one more thing, you've got the electronic dizzy yes? is it pluged in correctly? you have to unplug it when you crank it with no spark as otherwise it can short itself out internally and it's fucked then
Old May 23, 2012 | 07:33 PM
clyde 1800's Avatar
clyde 1800
whats the afm sorry?
i cant imagine it being the dizzy because the car is still running?
throttle position sensor is a real possibilty to
thankyou for all your help
Old May 23, 2012 | 07:36 PM
dojj's Avatar
dojj
afm = air flow meter
tps = throttle position sensor
you may need to reset the base idle to get the tps set up corectly, lots of info over on the ford sierra forum if you need any pointers
Old May 23, 2012 | 08:31 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
obvious but is the head an injected head and not carb?
Old May 23, 2012 | 08:50 PM
E980VTJ's Avatar
E980VTJ
unplug the air flow meter and see if it gets worse
Old May 24, 2012 | 07:16 AM
clyde 1800's Avatar
clyde 1800
its a full injection set up
and when the air flow is unplugged the car just dies out
Old May 24, 2012 | 09:47 AM
E980VTJ's Avatar
E980VTJ
which suggests it working,but do not try pattern afm as have had 2 brand new duff ones on my van
Old May 24, 2012 | 12:57 PM
dojj's Avatar
dojj
Remove the inlet manifold, very easy to check the head as the ports are egg shaped rather than round
Old May 24, 2012 | 05:02 PM
costina's Avatar
costina
Live long and prosper!!
have u got the wiring correct? from memory the black wire is not an ignition live feed. mine would not rev past 4k check diagram
Old May 28, 2012 | 06:11 PM
clyde 1800's Avatar
clyde 1800
what wire is that? you may be on to something here
basically when u gun the car it just goes baaawwwhhhh!
and its definatly an injection head for sure no doubt about it
today i unplugged the throttle position sensor and gave it a run but had no different affect on the car
Old May 28, 2012 | 07:53 PM
clyde 1800's Avatar
clyde 1800
bump up new posts
Old May 29, 2012 | 07:11 AM
clyde 1800's Avatar
clyde 1800
bump up today
Old May 29, 2012 | 07:36 AM
BigErn's Avatar
BigErn
Is the centre electrode inside the dizzy cap still in? Had them fall out as you fiddle with them to get them on then the car idles but misses or cuts out as soon as you rev/drive it.
Old May 29, 2012 | 07:10 PM
clyde 1800's Avatar
clyde 1800
ok so today i removed the injection system and put on a twinchoke carb inlet
i fiddled with the dizzy to get it idling just right and fiddled with the fuel pressure regulator aswell
when i done this though the car will only idle and will just cut out if revved
the exhaust is putting out smoke but the oil level is ok
Old May 29, 2012 | 07:40 PM
boy-racer-1
sounds to me like the fuel pump/ regulator can only supply enough fuel for idle and then cuts out when you want more, im guessing this engine is run off an electronic fuel pump being that its efi? i would look at trying a different pump if the regulator is working fine
Old May 29, 2012 | 08:08 PM
clyde 1800's Avatar
clyde 1800
its an electronic twincam fuel pump but i have a fuel pressure regulator in the line ive tried putting the fuel up slightly but just dies out with even the slightest tweek
Old May 29, 2012 | 09:39 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
Check the fuel pressure, as said, it sounds like the pump can't cope.
Old Jul 5, 2012 | 09:31 PM
clyde 1800's Avatar
clyde 1800
thanks for the help lads
ripped it out and dropped in a twincam engine
parts etcc are easier sourced and more power
tankybaby66
Feb 6, 2016 02:24 PM
20/20 vision
Sep 29, 2015 11:27 AM
martynhomer01
14
Sep 23, 2015 12:23 AM
little bram
Sep 21, 2015 02:50 PM
little bram
Sep 7, 2015 11:59 AM
