Battery light flashing when wipers are on, low voltage?
Noticed this last night when I was driving home in the dark, it was pissing rain, heaters on, stereo on, lights on, wipers on.
I saw the battery light flash every time the wipers moved, but also the rev counter kicks at the same time also?
Firstly i put it down to low voltage then I thought it must be a bad earth somewhere, thoughts???
Try using a jump lead from the alternator + to the battery and turn everything on with the engine running and see if it helps, if it does then it is time for a battery to alternator re-wire.
Adam Graham
06-09-2015 06:04 AM
