2003 Connect glow plug light then cuts out
Old Mar 26, 2012 | 08:59 PM
NARNA-P's Avatar
NARNA-P
WAAARRRRPP TTSSSSCCCHHHHH
Default 2003 Connect glow plug light then cuts out
As in title my 2003 tranny connect 90ps cuts out some times can go day 2days without doin it then it'll do twice in a row. Starts back up straight away . glow plug light comes on then bang cuts out am i right in thinking that the glow plug light is the management light ?
And has anyone had this issue on a connect before as im aware its common on mondeo tdci's but they're different engines
Thanks
Old Mar 27, 2012 | 07:23 AM
oldford's Avatar
oldford
Glow plug light is used as a MIL, Engine Check, management light, whatever you want to call it.
Normally I would say get the fault codes read. However, diesels tend to forget the code when you switch off the ignition key. Possibly here too. Am I correct in assuming the glow light stays off after the restart?
When it stays on, you can have the codes read.
Old Mar 27, 2012 | 06:21 PM
NARNA-P's Avatar
NARNA-P
I was gonna get it plugged in anyway just to see if it does throw anythimng up. The light does go off after starting up again but some times the light comes on then instantly cuts out others it can flash for a mile down the road then cut out. My mate had a similer problem on a 06 plate focus 1.6 petrol and that turned out to be the accelerator pedel sensor.
van_dogg_pavvy
Mar 3, 2016 09:30 AM
Alun Gregory
Sep 6, 2015 09:40 AM
Timmy74
Ford Mondeo Including ST
Aug 28, 2015 01:21 PM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
