2.0 sohc efi, big problems
Old Mar 26, 2012 | 05:46 PM
Bukko89's Avatar
Bukko89
Default 2.0 sohc efi, big problems
hi guys,
Right, long story short have an EFI unit and (most of the) wiring from a 2.0i sohc sierra and put it in a capri, i get a spark at all four plugs, plugs are wet so they have fuel, have setup the timing as per the haynes manual for a sierra and the hall effect distirbutor (no vacuum pipe) and it will not idle; it sort of semi starts then dies, if i put my foot on on the throttle it idles slightly about 1500 but i get backfire through the intake. Have also tried moving the distributor base but only makes the problem worse, ie: wont start or makes idle worse. Main running around 3000rpm it sounds ok but lower end and idle is terrible. Have tried the octane adjustment wires (earthing them) but has made no difference.
If anyone has any ideas i am more than willing to try anything at the minute ( apart from setting it on fire, which is close anyway)
The wiring diagram below is what i have connected up, again anything anyone can spot that would cause problems please let me know.
Orange is connected, black is not because i dont have it.
Also dont have an airflow meter? would this cause the above problems???
Thanks for any help.
Old Jul 5, 2012 | 09:37 PM
clyde 1800's Avatar
clyde 1800
to much fuel mate
you need to buy A FUEL REGULATOR
Old Jul 13, 2012 | 10:33 PM
landaqmabba's Avatar
landaqmabba
if it had an air flow sensor and you took it out could be as the engine dosen t know how much air is coming in sends more or less fuel then needed at least i think...
Old Jul 15, 2012 | 09:19 PM
johnnysash's Avatar
johnnysash
You need an air flow meter.
EoinXR3
Sep 7, 2015 05:44 AM
nicos#29
17
Sep 7, 2015 05:32 AM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Blown Hell
Aug 5, 2015 07:22 AM
