Bit of a break down !
Hi all my saff cossie died on the way home tonight , was fine this morning and was driving home fine but started to die on a roundabout (felt like fuel startvation)but caught it on the throttle ,a mile later it stopped altogether.
gor it recovered home and had a look has a good spark, and fuel getting through but just turns over, did fire up once but run very lumpy then died and is now resting in the garden . Any ideas please ??????
The pump primes and the plugs are getting wet .
Just tried it again and started fine and ran well, although idleing higher than normal , left it running for 5 mins then switched it off , tried again and nothing just turning over .
After running a few checks pulse sensor / cps and map sensor my last point of call was the temp sensor ! Which was unplugged some numpty had lost the metal securing clip and it simply slid off !
Bit of a clean and new clip and fired straight up
Big Thanks martiesmartie for the pm
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
M K
Shows & Track Days
16
08-11-2015 06:18 AM
03-11-2015 04:08 PM
