Cossie only starts on full throttle
Hi, my Cossie died the other night on the way home it will now only start while pumping the throttle even then runs a bit rough , I've changed plugs , cleaned cap and rotor arm , and checked cps and pulse sensor .
When running shows 2.5 bar of fuel pressure .
Any ideas ?
Any ideas please ?
Any ideas ?
Any ideas please ?
That's a low fuel pressure.
Normally you should get around 3.0 bar on idle and 3.5 bar with disconnected vacuüm hose.
Maybe check fuel filter and measure fuel flow?
CabrioTurbo
Aug 1, 2015 11:04 AM
