cambelt tensioner
Old Mar 24, 2012 | 06:06 PM
snoopaloopa's Avatar
snoopaloopa
Default cambelt tensioner
Just went to put my cambelt back on, 1.8 zetec silvertop, and found that there is no spring tensioner, I have the tensioner wheel obviously but no spring or pin screwed into the head, question is should it be there?
The cambelt was changed last year at a garage but now I know I'm a little concerned, should I be or not? and if I need it where would i get just the pin and spring?
Old Mar 24, 2012 | 06:52 PM
GVK.'s Avatar
GVK.
In the genuine Ford kits they used to have a pin and spring included. Haven't fitted one for years, so not sure if they still do.
Pic shows spring.
Edit - Ford finis 1112531 kit does.
http://www.fordonlineparts.co.uk/pro..._F1112531-2665
Old Mar 24, 2012 | 07:57 PM
snoopaloopa
Yeah thats what i'm missing, cant see it being right without it as it cant self tension the belt.
Old Mar 24, 2012 | 08:03 PM
GVK.'s Avatar
GVK.
On the silver top, the spring only pulls the tensioner when you're fitting the belt with the centre bolt loose.
If it's tensioned properly without the spring it will be fine.
On engines like the Zetec SE, the tensioner floats against the spring and self tensions.
Old Mar 24, 2012 | 08:06 PM
snoopaloopa
Ok cool,Just got an original ford kit for £17 off evilbay spare belt now as well
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
Chas
Oct 5, 2015 07:13 PM
dombanks
Sep 21, 2015 08:38 PM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
mrknifey
Aug 30, 2015 11:48 AM
