Series 2 Escort RS Turbo ECU question!
A Webb
right...i have no spark at all from coil and i changed the coil...i have a D reg early Escort RS and i got the BLUE RED WHITE squares on it, i think that its knackered and my friend has lent me a series 2 90 spec i belive corect me if im wrong with the HEART DIAMOND AND HASH on it,will this work on my RS i plugged it in and i still have no spark so does that mean is something elselike wiring or is the 90 spec ECU uncompatalble?
ecu's are compatible. must be something else, check coil/connectors, leads,dizzy and/or rotor arm. loose connectors on the coil arent unheard of.
Check for live on coil with key on 12v. If ok..
Get a test light or 5w bulb in a bulb holder with 2 lengths of wire, connect to coil wiring with it disconnected. When cranking, it should flash on/off.
Also, when cranking the fuel pump should cut in, if it doesn't it's possibly the hall sender in the distributor, OR the wiring from coil.
Try disconnecting the distributor and try it again, it sounds as though the coil trigger (green wire) wire is shorted to earth.
If you disconnect the distributor and crank it and it doesn't stay on, fault is in the distributor.
Really need to check the wiring from the coil all the way back to the ignition ECU.
Can you get hold of another distributor to try?
muz
16-08-2015 12:57 PM
